Miklos C.
Miklos C.
Miklos C.
Customers reviews - There are 19510 reviews.
efficace oui ; magnifique !
Franck D.
Cdt.
Marc M.
jean francois F.
le son tube à prix cassé!
Didier R.
Bon boîtier mais
patrick b.
eric v.
efficace
dosage précis a l'utilisation
eric v.
conforme
eric v.
efficace
TECCE V.
Eccellente
TECCE V.
Ottimo
TECCE V.
Ottimo
Jose Vicente C.
Good cable
Michel B.
Michel B.
Les plus:
-Montage simple
Les moins:
Michel B.
Très bien !
Les plus:
Les moins:
Michel B.
Les plus:
-Pas cher.
Les moins:
Michel B.
Très bien !
Les plus:
Les moins:
Serdar C.
Fantastic!
I was stuck with my mainboard's soundchip before and I thought that was already good, but the Khadas Tone Board slaps me in the face and showed me what really good sound is. It's like as if an additional layer of detail appeared out of nowhere in the music I normally listen to on a daily basis. I use a DT990 (600 Ohm) with the Schiit Magni Heresy for my listening experiences, the KTB completed my humble setup. If this DAC were a car, it would pass easily as a sleeper.
Serdar C.
Compact goodness!
This small aluminium case is compact, well-machined and not distracting, the way a DAC should be.
However, the screws that came along the generic version of the KTB (also bought from here) don't fit between the case and the board. You can have it "hover" inside, the screw-rings of the RCA ports are sufficient enough to keep the board in place.
I like this product regardless, thanks Audiophonics for the lightning-fast delivery!
pratique
J'ai commandé ces cosses "no name" en même temps que les MUNDORF de même taille et de même prix. J'ai préféré utiliser les premières qui permettent un double serrage alors que les MUNDORF n'en ont qu'un seul ...
Petite pince nécessaire dans tous les cas bien sûr.
Patrice R.
sang c.
very good....
sang c.
very good.....
sang c.
very good....
Jean-Pierre P.
Serge S.
excellent produit
PATRICK F.
PATRICK F.
PATRICK F.
PATRICK F.
sandy o.
yes it does sound better but?
Jean Pierre G.
Michel E.
Insert de qualité
Robin A.
Fonctionne parfaitement
Circuit très propre, belles soudures, matos de qualité. Le bluetooth fonctionne parfaitement, connexion très rapide.
Par contre manque d'infos sur les watts RMS, c'est la puissance MAX qui est indiquée, donc il faut diviser par 2 en moyenne.
La sortie Sub fait donc en réalité 100W RMS mais sous 2 ohms ! Donc 50W RMS sous 4 ohms. Les deux autres sorties font 50W RMS sous 4 ohms. La puissance est suffisante pour une grosse enceinte nomade.
Attention, la sortie Sub n'est pas filtrée, donc il vaut mieux prévoir un filtre passe-bas pour optimiser les fréquences.
La livraison a été plutôt rapide et le colis bien emballé.
Satisfait de ma commande.
Michel E.
Pointe et contrepointe idéale
Ce système de découplage est parfait sur le rendu sonore en particulier sur de grosses enceintes avec un grave dégraissé clair dynamique. De plus ces pointes permettent de déplacer les enceintes sans efforts et sans risques de rayures. Le prix est justifié.
Philippe R.
Mais...
Produit de bonne qualité, parfait pour mettre sur un appareil qui doit être posé. Pour un appareil un peu lourd (ampli..) qui doit être glissé sur une étagère, les boudins en caoutchouc ne glissent pas et sortent de leur emplacement.
Roberto C.
Fully satisfied
Excellent and fast service, and the quality I expected from an nCore amplifier
Jean-Claude E.
Pourrait mieux faire
Pour une question de vis trop courtes.
En effet les 8 vis 3 mm tête fraisée du capot et du dessous ne prennent que quelques tours sur les écrous noyés et si on serre trop fort, ça foire. J'ai du commander des vis 2 mm plus longues. Dommage, car ce coffret est bien fini.
Christian A.
Attention, le cordon secteur (embase en trèfle) n'est pas livré avec le boitier
Laurent l.
Correction de mon 1er avis (version KIT)
Attention, souffle constant généré par le mini DSP lui même ainsi que du bruit (click et autre fuzz synchronisé en fréquence avec la led de la carte).
Il n'y a pas de solution pour le stopper: Ni une alim de course, ni Les entrées en court circuit (moins pratique pour écouter de la Musique).
Dès que vous insérer ce PROC dans la chaine du son, les souffles & bruits divers sont clairement audibles.
Pour peu que votre système ait un haut rendement...
Le forum MiniDSP a jeté l'éponge. Il s'agit visiblement d'une erreur de conception ou masse analogique
est commune avec la masse numérique.
Comme le dit le forum MINIDSP, une fois que la Musique joue, on entend plus le souffle...
Il semble que seul le procsymétrique soit incriminé. La version non symétrique RCA n'a parait-il pas ce problème. Ma carte date d'il y a 3 ans.
Claudio c.
IBASSO IT01S In-Ear Monitor Dynamic Driver Nanotube Diaphragm Ø10mm 16 Ohm Blue iBasso reinvents its range of mid-range in-ear headphones with the IT01s, specially designed for audiophiles looking for exceptional playback. Using an assembly of high-end...
UN SANS FAUTE BRAVO IBASSO
Cet paire d'intra est vraiment formidable , beau packaging rien ne manque surtout pour son rapport qualité prix imbattable.
Confort design au top et le son tout simplement bon dans tout les registre, c'est du ibasso quoi qui vous offre une qualité sonore audiophile à un bon prix. Je possède des campfire audio qui coutent dans les 800 à 1200 euro et sérieusement cet écouteur n'a pas ç rougir devant eux surtout pour son prix.
Bravo à l"équipe audiophonic pour leur professionnalisme et rapidité dans leur traitement des commandes.
C'est mon deuxième
Câble qui vous révèle le contenu de vos fichiers numériques et révéle la richesse de vos CD ,le mauvais son numérique c'est le jitter,je pense que la qualité des connecteurs est pour beaucoup dans les bons résultats de ce cable qui en diminuant le jitter de la chaine numérique du système en améliore le réalisme de l'écoute .
Jean Luc C.
Beau connecteur
Connecteur qui présente un excellent rapport qualité /prix. Compte tenu de la qualité de fabrication. A associer au connecteur shucko assorti. Achat hautement recommandable
Jean Luc C.
Beau connecteur
Belle qualité de fabrication, montage réalisé sans trop de difficultés, la clef nécessaire pour le serrage des câbles est fournie c'est un détail, mais il faut le dire.
Mais le plus surprenant est bien la qualité du connecteur, celle des fiches en cuivres, et de leur systèmes de serrages notamment. Un rapport qualité/prix très surprenant.
Un achat a recommander vivement.
Bastien S.
Complément à mon avis précédent...
Sur mon avis précédent j'ai oublié de préciser que le son de ma TV est retranscrit par ma chaîne hifi (d'un assez bon niveau) via un câble optique Viablue H-Flex...
La combinaison d'un bon câble d'antenne et d'un bon câble optique permet d'obtenir un son de très bonne qualité.
Evidemment si l'on utilise les HP intégrés de la TV, le son sera peut-être un peu meilleur mais restera forcément quelconque !
Avec un bon câble d'antenne et une bon équipement audio, on réalise que le son de la TNT est excellent, nettement supérieur à la qualité CD...
Mais du coup, on regrette d'avoir si peu de bonnes émissions musicales.
Qualité
La qualité est là, ces bornes sont belles et pratiques, bien que j'aurais aimé avoir un écrou de serrage 6 pans à la place de moleté, pour un serrage à la clé.
