pascal B.
petit tweeter
rapport qualité/prix exceptionnel pour ce petit tweeter qui associé à 1 large bande de 13 cm a permis de restaurer de façon...
Eric v.
connexion
Eric v.
Indispensable !!
Customers reviews - There are 19221 reviews.
Raphaël B.
Une cloche pas cloche
ça marche, que dis-je ? ça trou, très bon produit, j'ai pu faire ce que je voulais.
RB
Hendrik W.
Wonderful cable for pre-amp
I was a bit sceptic about the improvement this cable would make to my equipment. I have made one to my Denon AVP-A1 pre-amp and the improvement was hugh. Some very good noticeable improvements:
- Overall sound clearity.
- Sound stage in height.
- Highs are much more natural.
- Bass is not more but thightend up.
- Volume on same settind needed to be increased.
Note that this cable needs to settle for about 40 hours. After connecting and playing for about 2 hours I was worried that this was wrong cable as soundstage was 'moving around', but after settling down the above mentioned improvements were very obvious.
I also made a cable voor my Denon AVR-2313 in an other setup in different room. Also improvements here, but not as spectacular as with the AVP-A1. I only use it in 2.1 setup and the improvements here are:
- For me no need for subwoofer anymore (more and thighter bass).
- Stereo setup is sounding really 3D in good film sound recording and therefor no need for center speaker (as I was thinking about before applynig this cable).
Kind regards, Henry
CHRIS E.
An excellent and affordable DAC
After reading a lot of comments about the dx3 i pulled the trigger and i bought one from a reputable seller like Audiophonics in an excellent price.
Pros
The Dx3 dac i(ldac version) so far is working fine, quality of sound and construction is excellent and the remote is upgraded to take normal triple A batteries.
Beats much more expensive DACs in sound quality.
Cons
Need a better display where it can show the sample rate and bit resolution all the time and not just the sample rate for 2 seconds when it is switched to a different value ONLY
Recommendation for the future
I wish Topping will eventually put out a product which has a big display and can read directly USB3 hard disks so i don't need a separate computer in order to play my music files.
Chris
Michael L.
Super mini amp
The amp is a mini non nonsens class d amp
I use wharfedale diamond 225 speaker and a 24 volt 6a power supply
It sound really good and loud,it might have a little enhanced bass and sometimes the highs especially if played a little loud (it can go loud with a 24 volt power supply) changes to a more pronounced,forward highs, as long as you keep it within it's limteds there lot's of good sound.
It almost sounds as good as my TPA3116 amp with a tube t1 preamp. Im not 100% shure if it sound better, it does how ever sound better than my TPA 3116 amp without the tube preamp.
Solety B.
Tout d'abord je félicite le service expédition pour la rapidité et le bon emballage.
Concernant le produit, il est très bien construit, joli en silver et la télécommande ne fait pas cheap. Elle réagit même très bien avec une bonne sensation de pression sur les boutons.
Précision à son sujet, elle permet de stopper la lecture et aussi, contrairement à ce que j'ai lu plus haut, d'ouvrir et fermer le tiroir. Peut être est ce une modification.
Pour le rendu sonore, c'est merveilleux d'ouverture et de douceur. Il ne fait pas dans la sur definition et le spectaculaire mais au contraire il joue avec rigueur et douceur. Les timbres sont très beaux.
Utilisé avec un convertisseur, on peut gagner en définition mais pas nécessairement en plaisir.
J'ai eu un sac audiomat maestro 2 associé à un drive audio note cdt2 et très sincèrement je cherche les différences. Ah si, le prix!
Bref, une petite bombe répondant parfaitement à mon utilisation.
Je n'ai pas essayer le port USB.
Bonjour chez vous.
Jarkko M.
Good result!
I don't give 5 stars because you need to shave off the stands like around 1,5 mm. Also be sure to carefully think how you will tighten the thing up.
It takes just little patience but if you don't hurry the finalized box looks really good!
Fernand M.
Excellents conseils et très bon produit
Merci pour votre écoute attentionnée des besoins de vos clients et pour vos excellents conseils de professionnels avisés. Je ne puis que me rallier aux avis des autres acheteurs concernant les étonnantes qualités audio de cet appareil.
claude v.
juste génial
bien souple facile a étamé parfait utilisé pour faire un câble de liaison de 10m bon par contre la gaine tresser est une véritable galère a mettre y a surement une méthode ou un outil mais bon au bout de 3heure a fabriquer mon câble le son sort clairement avec des basse plus présente un medium aiguë précis rien a dire c'est du tout bon
Un rapport qualité prix imbattable
Je trouve Hervé un peu sévère avec se tout petit dac ,j,ai eu l'occasion chez un ami de le comparer à un convertisseur TOTALDAC qui valait 20 fois son prix et la différence d'écoute
je vous l'assure n'était pas abyssale loin de là !
Nous avions fini par en conclure que ce petit smsl pouvait aller jouer dans la cour des grands même à 20 fois moins cher!
Exceptionnel qualité pour ce prix !
Marlen M.
MUNDORF CFN14 Copper Foil Ferron Core Coil Zero-Ohm 6.8mH This new range of Zero-Ohm coils combines a hand-tuned Feron core with the extreme conductivity of a Copper ribbon. This technique allows to reach a very good pulse reproduction...
Bad Quality
Measures with very big 3rd harmonic and bigger 2nd than with cheap Ferrite Inductors :(
When removed I plate "I", distortions became as with ferrite/air, but inductance has fallen almost in 3 times.
I do not recommend this inductors in Hi-Fi Loudspeakers.
You can see my THD measurements on 2x26W/4867 in this link https://cloud.mail.ru/public/23VP/2PWf2v4Se
6.8mH was measured with 2.83V; other measurements with 8V RMS in same conditions.
Excellent !!!!
Câble, malgré sa taille, souple et facile à dénuder. Un petit rodage semble gagner des ++ à tous les niveaux : finesse, précision, détails et subtilités de tout enregistrement de qualité, et quelque soit la musique, ce câble excelle par sa qualité de restitution. Pour ma part j'utilise ce câble en asymétrique relié comme suit : fil rouge au point chaud, fil blanc au potentiel 0v du circuit et la tresse de blindage n'est reliée que d'un côté au 0v et ne sert donc pas à véhiculer la modulation. Une petite gaine thermo sur la gaine du câble Furutech sert à repérer le côté de la Cinch où la tresse est reliée au potentiel 0v. Les Cinch sont des Eti cuivre pur, comme les Cinch chassis Eti des appareils connectés. Le résultat est sublimé ainsi et les oreilles sont aux anges ! L'écoute de " Concerts Naturels de l'Ardèche " de Pierre Palengat, m'a permis d'être totalement captivé et étonné de la subtilité des chants d'oiseaux, ce qui me permet d'approfondir mon désir de reconnaissance de ceux-ci lors de mes promenades en milieux naturels. Sur les sons acoustiques, tous instruments confondus, c'est une redécouverte totale de ma discographie, où je suis contraint de m’asseoir et de ne faire qu'écouter tellement je suis captivé et comblé de détails jusque-là passés inaperçu. Pierre R.
OLIVIER D.
Rétroéclairage
La spec indique que l'ampoule de rétroéclairage demande 55mA sous 2,5V. Or, à cette tension, son filament est à peine jaune. Il semble que 5V soit la tension requise.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 8.2µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
MUNDORF BL140 Air Core Self 1.4mm 0.15mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
MUNDORF BL140 Air Core Self 1.4mm 5.6mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Produits conformes à la commande. excellent emballage individuel. Colis, juste la taille nécessaire pour une bonne protection mais pas de sur-sur-sur emballage comme "Amazon" et d'autres malheureusement. Expédition très rapide. Un grand bravo à Audiophonics. Merci
DYNAVOX Banana Plugs Gold Plated Ø4.5mm (Set x4) These Dynavox banana plugs have been designed to provide an excellent connection to your speaker terminals. The expansion chuck at the rear of the plug allows the contact to be...
Fiche trop courte
ATTENTION
Quand j'ai vu la longueur de la partie entrant dans le bornier j'ai eu comme un doute.
En effet si vous avez des jumpers à la fourche épaisse et des des écrousde borniers au plastique un peu épais (dans mon cas), la fiche est trop courte et même bloquée à fond ca brinquebale et ce n'est pas signe d'un bon contact.
Heureusement je n'ai fais qu'un seul côté pour essayer.
Donc retour à la case départ.
Marino M.
FX audio
Après un petit rodage... Ampli jouant dans la cours des très grands.
Superbe définition que soit dans les graves et les aigus !!!
Olivier P.
excellent petit ampli rapport qualité/prix imbattable
Ce petit ampli fait merveille, j'avais également le SMLS A18 qui était excellent. Mais celui-ci est très élégant, plus doux, très défini et cependant il a la patate ! Parfait pour une chambre ou un bureau. J'ai recyclé mes vieilles colonnes Davis, Qobuz sur mon portable et connecté au bluetooth 5 de l'ampli c'est du bonheur pour un prix... Foncez !
Anders L.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Transparent This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
Transparent sound
I used this wire to make a quad cable for bi-wiring speakers. The result is very good. To my ears this wire carries a highly detailed and transparent sound. Unsurprisingly, the mids and highs are very clear and detailed. I even used them for the low-pass connectors, as electrical symmetry is important in my experience. The bass is very detailed and true to the recording. If the recording has high bass levels, so does the speaker with this cable. (I needed to play the system with this new cable for about a week for the sound to settle in.)
My preferred speaker cable used to be unplated single core copper, for the transparency and transient delivery. The only draw-back with that is a roll-off in the high frequency band. This Audiophonics cable is the first thing I've found that has the same transparency and attack but with better frequency extension.
The strengths of this cable is particularly evident when playing recordings of instruments with a great range, such as piano or cello. All the notes have a similar sound signature in terms of resulution and sound presssure. This provides a very stable spatial reproduction.
I will definitely be making more speaker cables from this wire.
claude M.
Je suis très satisfait de ce produit qui confère au son dématérialisé provenant de Apple Music une sonorité identique à mon drive CD haut de gamme . Le son est aussi plus défini et la scène stéréo est plus profonde comparé à une transmission via Airplay à une borne Airport . Seul bémol , il n'y a aucune explication sur le téléchargement du pilote . J'ai mis une heure à comprendre qu'il fallait que j'ouvre le pilote via Itunes .
Ben S.
ALLO Aluminium Case for Allo USBridge Signature Black This Aluminium case has been specially designed by Allo to cover the USBridge Signature, protecting it from dust and shocks. The housing is drilled so that all the USBridge...
excellent housing (case)
I bought everything last (Sunday) ,with the usbridge signature
.Everything goes super fast from audiophonics
Ben S.
ALLO USBRIDGE SIGNATURE Audio Streamer Raspberry Pi Compute 3+ Ultra Low Noise USB Interface The Allo USBridge Signature is a network drive based on an SBC Raspberry Pi Compute 3+ and the DietPi operating system. It allows to reduce the noise of the Pi Compute and all...
Allo USBridge Signature works amazing beautiful!
I bought this last Sunday, usbsignature and a ALLO Aluminium Case for USBridge Signature
I have try dietpi first and that is good with roon , only I'm going to Ropiee and it works beautiful!
Wow ,this is recommended
gary w.
arcana hybrid 1877
unfortunately i cannot review product as it was stolen whilst in transit in england.
jean michel G.
Capa de bonne qualité
Acheté pour remplacer les deux condos de puissance légèrement gonflé sur un luxman A384, mise en place facile avec maintien du double face.
Excellent.
Ludovic f.
parfait !
Rien à redire sur le produit rapport qualité prix je pense imbattable. Le rendu est tout à fait honorable, rien ne sert de mettre beaucoup d'argent sur un câble qui apportera sûrement un effet placébo, le plus important c'est la qualité du cuivre, donc pour ma part rien à dire c'est vraiment très correct surtout au vu du tarif.
Concernant audiophinics la aussi parfait rien a redire comme d'habitude, j'ai demandé de m'envoyer cette commande rapidement, commandé un dimanche et reçus le mardi. Merci à toute l'équipe audiophonics.
Paulo Fernando A.
TINYSINE TSA6016 Bluetooth 5.0 aptX Receiver Board wih Microphone Input This Bluetooth 5.0 aptX receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this...
Best Bluetooth receiver ever!
I have tried many Bluetooth receivers over the years, this one is the best! The sound quality is as rich as cable quality, and also no interferences during phone calls. Finally I found a prime quality Bluetooth to use in my car.
Pascal M.
Bonne marque
Le câble est très bien fabriqué.
Rachid Z.
XDUOO XC-08 Adapter Cable Female Angled USB-A to Male Angled Micro USB 8.5cm This xDuoo XC-08 adapter/cable has a female USB-A connector and a male Micro USB connector. A particularly practical adapter for connecting a USB-A device or cable to a device...
Erreur de conception !
Dommage que le câble sorte du mauvais côté de la prise micro USB... du coup inutilisable pour connecter mon XDuoo XD-05 avec mon smartphone !
Grzegorz B.
Very good quality, necessary product!
It is necessary product with all screwed connections. I use PEW12 system to crimp and it allow to almost homogeneous material from sleeve and wire.
Grzegorz B.
Grzegorz B.
Grzegorz B.
Grzegorz B.
Grzegorz B.
Very good quality, fast shipping from the shop.
I changed speaker terminal from WBT 0780 (chromed brass) on Mundorf Mconnect (gold plated copper). The sound is much better, more detailed, more opened, with deeper bass. Terminals are more comfortable with big nuts. Thank you Audiophonics for fast shipping.
Laurent T.
Impressionnant !!!
Je suis réellement stupéfait par ce "petit" Ibasso Dc02 , branché sur mon Huawei mate 20 pro qui a une sortie son un peu juste l'apport est impressionnant , c'est nettement plus fort et la qualité s'est nettement améliorée bref le top !
Je pense que le rqp de ce ibasso doit être vraiment difficile à surpasser
Jean-Louis l.
Très bonne qualité
La qualité de ses fiches est véritablement excellente. Elle est au-dessus de mes attentes. C'est une valeur sûre.
Jean-Louis l.
Rien à redire sur la qualité de ce produit qui est conforme à mes attentes.
Pierre F.
Déception
Utilisé à la place d'un TacT RCS, entre une Mutec MC3 Smart Clock USB et deux amplis TacT 2150, reliés en toslink (sans utiliser les DSP, donc), la qualité sonore a nettement reculé : perte de la scène 3D et timbres ferraillant.
La praticité de la télécommande et la facilité des réglages pour un système multivoies sont indéniables, mais ils ne compensent pas la qualité très moyenne du son.
Ce n'est pas un appareil haut de gamme et cela s'entend.
Michel C.
Pied caoutchouc Amortissant
Je suis satisfait de mon achat la hauteur de 30m/m est impeccable
pour mes Audio Researsch Sp9 mk ll et classic 30 !
ils avaient besoin d'air pour les ventiler
Pieds d'origine 20 m/m !
Alan M.
VIBORG VP-1501 Power Cable OFC Copper 4N Copper Shield 6mm² Ø16mm The Viborg VP-1501 is a high quality meter-to-meter power cable. It will allow you to design your own power cables.
VP-1501 POWER CABLE
Incredible value for money..an exceptional build quality cable,
Guillaume V.
mini...
...mais il fait le maximum!
les+;
modulable dans tous les sens:
-utilisation autonome sur batterie.
-gain et basse réglable avec 2 boutons pour s'adapter a toutes les installations.
-resultat global du son trés satisfaisant (transforme le son d'un ordinateur).
les- ;
-en cherchant bien peut être...
pour ma part je ne vois rien a redire.
Anders L.
Superior value
These plugs are very good. They are very well machined, particularly to avoid an excess volume of copper (eddy currents etc). They fit very well in speaker terminals.
The packaging is also excellent with a hexagonal key and four marked shrink sleeves in each box of quality paper.
I would also commend Audiophonics for their speed of service and thoughtful stock. Everything I have bought so far has been exceptional value at their respective price points. Excellence s a rare thing these days, but Audiophonics is a truly excellent trader.
Anders L.
Functional and aesthetic
I used these to add volume to the conductors in a home-made quad type speaker cable. The conductors were Audiophonics 4 sqmm silverplated hookup wire with PTFE insulation. The purpose was to reduce the potential for cross-talk between conductors.
This cotton sheath was perfect for the job. It was easy to insert the conductors and then stretch the sheath to a tight fit. The knots in the weave also made it easy to twitst the conductors together.
The natural cotton also adds a beautiful aesthetic to the cables, so I would recommend using this sheath as often as you can in your builds.
didier s.
Mitigé
Ce DAC est tout à fait correct au niveau de la qualité sonore, par contre l'exemplaire reçu s'est rapidement montré défaillant au niveau de l'affichage OLED, ainsi que par l'apparition d'un bruit parasite sur l'un des canaux à chaque changement de track / chaine tv, …
Un appel au SAV est lancé pour ce produit.
Serge D.
Produit conseillé
J'ai acheté ce produit pour réparer un caisson ELIPSON "HORUS"
Ce module m'a été livré en excellent état. Il me donne entière satisfaction.
Je recommande donc ce module.
Pieter T.
good bitumen, very sticky so be warned
good bitumen, delivered as plate, flexible without being warmed up
it sticks good on sticky side, however the other side is very sticky too when foil is removed, so be warned when you put something on top
Victor S.
Cédric C.
Mr Cédric Chassaing
Bonjour.
C’est bien la première fois que je rédige un commentaire de satisfaction après achat. J’avais cependant déjà possédé des câbles Oyaide au sein de mon système hi-fi. Alors lorsque j’ai constaté que la marque proposait un câble de remplacement pour le fameux HD-650 de Sennheiser, modèle de la marque et référence de très nombreux amateurs du casque ouvert dont je suis, j’ai tout de suite voulu essayer d’ « influer sur ce maillon faible de la chaîne » en remplaçant le câble d’origine de 3.00 m par celui de la marque japonaise réputée, pour la pureté de son cuivre, sa teneur en argent et sa longueur d’1.30 m. A l’époque du test initial, mon casque était branché dans un DAC OPPO HA-2 SE, lui-même branché dans mon iPhone connecté à Qobuz abonnement Hi-Fi Sublime+ (via un câble USB / Lightning Audioquest Cinnamon 15 cm). L’ampli du DAC était muni d’un amplificateur des basses fréquences ; avec le câble d’origine, j’avais pris l’habitude de l’enclencher, (bass + on), bien que généralement je n’utilise de correction de tonalité sur aucun de mes systèmes, afin d’éviter tout risque de filtrage en peigne. Le seul faible défaut imputable aux écouteurs Sennheiser est en effet, un léger manque d’assise dans le grave. Or, une fois l’amplificateur des basses éteint, (bass + off), et le câble Oyaide HPC-35HDX Jack 3.5mm 1.30 m branché, ces basses fréquences sont apparues avec beaucoup plus de définition et de densité. Il délivre à peu de frais ce qui manquait à ce très grand casque de moyenne gamme (moins de € 350,00) fabriqué par l’un des meilleurs constructeurs en la matière. L’association devient donc évidente. Existe en black et silver.
Système d’écoute pour le câble :
OYAIDE HPC-35HDX
Câble Jack 3.5mm : https://www.audiophonics.fr/fr/cables-pour-casques/oyaide-hpc-35hdx-cable-35mm-pour-hd650600580hd-25sp-ii-13m-p-7729.html
pour HD650 : https://fr-fr.sennheiser.com/casque-audiophile-haute-qualite-hd-650
iPhone Xs Max : https://www.audioquest.com/cables/digital-cables/usb-lightning/cinnamon
OPPO HA-2 SE : https://www.oppodigital.com/headphone-amplifier-ha-2SE/
Bastien S.
Très bon ampli, nettement meilleur que le Smsl Ad18...
Après 2 mois d'utilisation quotidienne, voici mon compte-rendu personnel :
Il remplace un Smsl Ad18 que j'ai apprécié pendant 18 mois...
Et l'A8 ne joue pas dans la même catégorie que son petit frère ! Sans non plus ridiculiser l'Ad18, il est évident que l'A8 est (nettement) meilleur à tous les niveaux.
L'Ad18 reste d'un rapport qualité / prix exceptionnel, mais ses connectiques aléatoires et malcommodes, sa compacité et sa puissance modeste le limitent rapidement. C'est en particulier son entrée numérique coaxiale qui m'agaçait ( entrée jack qui réclame un adaptateur jack/rca) ainsi que les entrées analogiques (là aussi en jack)...
Avec l'A8, on dispose de vraies entrées numériques ( 2 optiques + 2 coaxiales) et analogiques en RCA. Seuls les borniers d'enceintes restent inférieurs à la dimension classique, mais ça ne me gène pas trop.
L'Ad18 remplaçait avantageusement un Atoll In80Se. Les seuls points sur lesquels l'Atoll restait meilleur étaient la dynamique et la "tenue" de la musique, grâce à sa réserve de puissance supérieure.
Sur tous les autres points, l'Ad18 était meilleur : à la fois plus détaillé et plus doux, plus musical et expressif, plus riche et vivant. Et je n'ai jamais pu revenir sur l'Atoll (qui est un ampli très honnête dans sa gamme de prix).
Avec l'A8 on retrouve la douceur, la finesse et la musicalité de l'Ad18, associées à la tenue et à la dynamique de l'Atoll, mais un bon niveau au dessus des deux autres !
Sur les entrées numériques spdif, l'A8 est aussi moins chaleureux et plus clair que l'Ad18 (plus smooth).
Je préfère la neutralité de l'A8, qui me semble plus naturel et tendu.
Je l'utilise sur l'entrée coaxiale numérique pour la musique et les films, et sur l'entrée optique pour la télé.
Et il faut souligner qu'écouter des émissions musicales devient intéressant, avec un bon câble optique, ainsi qu'un bon câble d'antenne (ce dernier pouvant nettement jouer sur la qualité du son et de l'image). D'ailleurs simplement écouter la télé peut aussi devenir un plaisir avec cet ampli, car dès que la prise de son est soignée (reportages animaliers et documentaires par exemple), c'est très immersif, vivant.
Je n'ai pas encore testé les entrées analogiques (en principe performantes en classe D), ni l'entrée USB.
Le dac embarqué me semble très bon, précis et équilibré. Mais ceux qui cherchent un son chaud le trouveront sans doute froid !
J'ai 3 reproches à formuler toutefois :
- Il est parfois un peu lent à régir via la télécommande, et il ne faut pas trop s'écarter de l'axe de l'ampli.
- A l'allumage, il arrive qu'il reste muet (en fait il reste en "mute", sans qu'il ait été éteint dans ce mode)... Il faut alors l'éteindre puis le rallumer : un peu agaçant.
- Sur l'écran (déjà petit) le volume s'affiche en minuscule, et pas moyen de l'afficher en information principale...
Alors comment décrire les performances de cet ampli ?
Et bien je dirais simplement que pour la première fois, j'ai l'impression qu'il ne manque rien à la musique : tout y est sans défaut ni excès.
Ce qui devient appréciable avec l'A8, c'est l'intégration évidente de qualités qui ont généralement tendances à s'opposer : douceur et dynamisme, précision et fluidité, richesse des timbres et tenue bien "carrée" de la musique, subtilité et punch, détails et ampleur, etc.
Ce qui me réjouit le plus, c'est sa subtilité dans les détails et les nuances (ambiances de salles, détails sonores d'arrière-plans, extinction de notes...), associée à sa capacité explosive, son équilibre général et sa poigne (très bonne tenue des graves).
Du coup il met clairement en évidence les limites de mes sources et de mes enceintes, (limites déjà perçues avec l'Ad18).
J'ai changé le câble secteur fourni par un câble secteur maison (blindé), et l'A8 apprécie, tout est plus clair et nuancé.
Pour ceux qui apprécient l'Ad18 mais veulent aller (nettement) plus loin en restant compact, l'A8 est un très bon choix.
En espérant qu'il sera fiable dans la durée.
Bonnes écoutes.
Bastien.
Gael J.
Du son et du vrai
J'ai redécouvert des musiques grâce à ce lecteur.Des basses enveloppantes et des aigus pas trop pointus . Une très belle définition. Utilisé en carte son de PC, il vous change tout. Un vrai plaisir. Il chauffe pas mal mais il envoie tellement du lourd que çà va. Heureusement que la batterie est grosse car il dépense de l'énergie, le petit coco. Je suis vraiment content de mon achat .
Emmanuel M.
J'en utilise depuis des années , aussi bien pour l électronique que pour mon caisson velodyne , les méga sont a privilégier même pour des électroniques d env 10kg ,car les petits se déforme avec le temp , et le prix est raisonnable ;-)
jean-michel L.
indispensables
bonne interface entre les pointes et le revêtement de sol, prix modéré, bonne qualité,en complément du support DAYTON
l'ensemble donne un résultat excellent, au delà de celui espéré
