Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Customers reviews - There are 19585 reviews.
Ralf S.
Best bang for your bucks :-)
Now this really is an extraordinary product, both Audiophonic's housing and Hypex' amplifier are way beyond the qualitiy that you can expect in this price range, if there is some famous brand label attached to the front... I particularly appreciate the switchable RCA/XLR inputs, as I use this power amp in a configuration that allows multichannel (R+L preamp output of my AVR via RCA) and pure stereo (via XLR). Now this stereo setup, which exists of the minimum number of components, is what really blows my mind. Source is an Eversolo DMP-A6, which can also serve as preamp and has balanced output, directly connected to the HPA-S600NCX via high quality XLR cables (of Funk Tonstudiotechnik in Berlin, Germany, who produce absolutely fantastic quality cables for nearly all audio applications) which serves to a pair of ambitious middle class speakers with 89dB efficiency. All this in a very small dedicated listening room, which does not allow for a proper bass reproduction. What should I say? The HPA-S600NCX delivers a precision in bass in this acoustically unfavorable environment that not even an absolutely high-end amplifier (an ASR Emitter, that a friend had lent me for testing) could deliver. I can only assume that the extremely low output impedance / high damping factor does the trick. Anyway, it's on a level which I never would have expected. As also the clarity of sound and the realistic performance over the rest of the frequency range is first class, I can highly recommend this amp even for high-end setups. For the fun of it: If you want to enjoy the potential of this little box, listen to Yello's "The Expert" from the "Touch Yello" album at a high listening level - I'm sure you will be amazed, too :-)
Benoit B.
HDMI to HDMI / Optical / Jack 3.5mm Extractor 5.1 18Gbps HDCP 2.2 4K 60Hz HDR ARC 3D CEC This extractor allows you to recover and extract an HDMI signal at the input and then output both in HDMI, Optical Toslink and Jack 3.5mm to distribute the audio signal...
Fonctionne parfaitement pour extraire l'audio d'une PS5 vers un kit 5.1 avec un câble optique.
Aymeric D.
J'ai commandé cet amli depuis la Nouvelle Calédonie, le suivi de la livraison a été clair, livraison rapide sans ennui.
L'ampli en lui même est compact, simple, il n'y a que deux boutons et une télécommande. Le bluetooth marche super bien. Le son délivré est très satisfaisant sur mes enceintes caisson équipées de haut parleur Supravox.
Un rapport qualité prix excellent !!!
Aymeric
Henri c.
JANTZEN AUDIO SILVER Z-CAP Capacitor 800V 2.2μF Jantzen Audio Silver Z-Cap capacitors maintain perfect sound neutrality and a very nice tonal balance. They are particularly suitable for use with a tweeter or midrange in...
trés analytique
j"ai utilisé ces condensateurs pour filtrer2 domes textile,monacord DT25n et audax TM025f1, chaque fois le résultat était très analytique
un extrême aigu bien présent,il faut utiliser un ampli a faible contre réaction avec un bon slew rate
Henri c.
tres bonne self
utilisé pour filtrer un 12cm fostex FE126nv ,le résultat est très dynamique,le son très vivant,ce haut parleur est très bon et la self ne
réduit pas ses capacités (sans jeu de mot )
Ideal
Une embase iec, un porte fusible et un interrupteur, en cuivre ofc ?
Connexion efficace, sonorité neutre .
J’ ai remplacé des neutrino plaque argent pour ces fiches viborg, plus de précision et de silence. Demande un temps de rodage .
Ludovic P.
Excellent avec Ifi Audio LAN ipurifier Pro
Utilisée sur un filtre Ifi Audio LAN iPurifier Pro, cette alimentation linéaire transcende le produit !
Meilleure aération et surtout disparition complète de la dureté dans le haut médium et des sibilances qui sont très présentes avec l'alimentation à découpage d'origine.
Pour ceux qui ont un LAN iPurifier Pro, je vous recommande absolument d'essayer avec cette alimentation !
Paulius S.
LHY AUDIO AC LINE Module EMI Filter for AC Power Supply This LHY Audio AC Line power filter filters out EMI interference from mains power. It is particularly useful for DIY power supply projects. EMI frequencies are filtered by two...
I implemented it to my CD player Denafrips Avatar, works very well.
AIYIMA A80 Integrated Amplifier Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm With its A80, Aiyima unveils a small integrated amplifier packed with audiophile features and components. It's primarily based on an ESS9038Q2M DAC chip and a TPA3255D2...
Un très bon rapport qualité prix
Dans un volume contenu, ce petit amplificateur delivre un excellente performance sonore et une neutralité appreciable dans le bas du spectre. L'afficheur est un pur bonheur pour les yeux. Néanmoins, les entrées trs n'offrent pas un gain notable par rapport aux classiques RCA ( intérêt?) et il manque une entree hdmi pour ma télé : 4 étoiles pour les fonctionnalités.
TINYSINE AUDIO-B PLUS Bluetooth 5.0 Receiver Module aptX Stereo RCA This Bluetooth 5.0 receiver module includes a Stereo RCA output for direct connection to a DAC or amplifier. It is therefore possible to use this module to stream your music...
Convenable
Fonctionne sans problème, son correct.
Incroyable mais vrai...
Branché à un ampli Taga Harmony 25 B, a permis d'obtenir un son d'une pureté et d'un détail incroyables, et surtout sans AUCUNE dureté à une paire de Focal Aria 906, magnifiques enceintes biblio, mais aux aigus un peu durs pour mes oreilles jusqu'à présent, malgré plusieurs essais de différentes combinaisons ampli/câble de liaison enceintes-ampli/ pièces...
J'étais sur le point de m'en séparer, mais là il n'en est plus question !
Il va de soi que je ne regrette qu'une seule chose : ne pas avoir acheté ce câble secteur plus tôt, le jeu en valant largement la chandelle en l'occurrence...
Nikolaus S.
Kombiniere die VE/VF512S mit dem "Supra Cables LoRad 2.5 SPC Silver Anniversary Edition", ergänze das ganze mit einem Baumwollmantel um die elektrostatische Aufladung zu überlisten und Du erhältst ein Top-Stromkabel für ca. 150,- Euro. Um dieses Klanglich zu übertreffen muss man ein Vielfaches investieren... (PS: kein Löten, keine Aderhülsen, kein gar nix)
Parfait sur un bureau
Je confirme les qualités évoquées lors des messages précédents : rapport qualité/prix exceptionnel, avec 3 entrées (BT, aux jack et usb) toutes fort correctes. Le seul petit bémol que j'ai trouvé est l'absence de réglage de tonalité (pas choquant à ce prix-là ! )
Sinon, il a redonné vie avec brio à des petites Jamo de vingt ans d'âge, mais peut également remuer quelques enceintes de type biblio...
Bref, bravo Audiophonics !
MICHAEL K.
Recommended
It does its job well. I paired it with a BST300 bass shaker and it's able to drive it quite nicely. Pretty significant difference compared to the Fosi V3 which I also tried but couldn't drive it as well as this one.
jean michel G.
jean michel G.
Heatshrink Braided Tubing 2:1 Ø20-22mm Black This 20mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the...
Gaine thermo adapté pour la finition, plus souple.
jean michel G.
Excellente
Très bonne gaine coton que j'utilise pour mes différents câbles.
Micael C.
Improve router performance
Installed post dual 3A LT3045 PS regulators powering my main wireless router with great results. Improves picture quality and sound quality. A strong recommendation.
Micael C.
Awesome SQ improvement
I have three of these powering two streamers and a DAC. Give a nice SQ improvement even after dual 5A LT3045 PS regulators. A firm recommendation from me.
HYPEX FUSIONAMP FA501 Plate NCore Amplifier 1x500W DSP ADAU1450 DAC AK4454 192kHz The Hypex FusionAMP FA501 plate amplifier can be used to design a subwoofer or speaker as an active channel. It is based on an NCore module capable of developing no less than...
Bon ampli et DSP paramétrable
J'ai acheté cet ampli pour alimenter mon subwoofer JMLab SW900 car l'ampli d'origine tombait régulièrement en panne du fait des vibrations (faux contacts sur le circuit imprimé).
J'ai donc sorti l'ampli pour qu'il ne soit plus soumis aux vibrations et cet ampli fait bien le job. La paramètrage du DSP se fait avec un micro et une carte son calibrés et les logiciels REW, HFD et rePhase.
Le processus de paramètrage se fait sans souci une fois qu'on a compris la méthode et maitrisé les logiciels. J'ai mis plusieurs jours avant d'aboutir au résultat final.
Cette petite critique n'est pas spécifique de Hypex car tous les DSP sont comme cela. On pourrait réver d'un logiciel intégré un peu comme Audissey dans les amplis Home-cinema qui fait à la fois la mesure, le calcul et l'implémentation...
Ceci étant je ne met pas 5 étoiles car le résultat acoustique s'est certes amélioré par rapport à l'ampli d'origine sous l'angle courbe de réponse mais s'est un peu dégradé en réponse impulsionnelle.
Cela est certainement dû à l'empilement des traitements avec un convertisseur ADC puis les filtres DSP puis le convertisseur DAC.
Néanmoins content de mon achat
Sébastien C.
SBOOSTER BOTW P&P MKII Regulated Linear Power Supply 24V 1.1A With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply....
Optimisation sonore
Une nette amélioration sur le rendu de mon pré phono Octave Audio.
L'image et la scène sont encore plus nettes avec plus de profondeur et une sensation de plus de détails.
J'avais un doute en passant sur une grosse version d'alim type LPS et cet achat était pour "tester". Finalement c'est largement concluant; Sans même dégrader le niveau de bruit de fond qui est quasi nul sur cet excellent pré phono.
Un petit "boost" qui vaut largement son tarif.
Laurent C.
LPSU200 HiFi Linear Power Supply High Fidelity 12V 7.5A + 9V 7.5A 200W The Audiophonics team is proud to be able to offer you a regulated linear power supply designed to supply clean power to digital players, storage peripherals, small systems...
Fait parfaitement le job.
Installée sur lecteur réseau 3dlab Nano transport PLATINUM V5, je suis très satisfait du résultat.
Davantage de matière, donc de présence, un gap sur la qualité des timbres, une scène sonore encore plus stable.
Pour le prix, Comparé à une alimentation 3dlab à 1300 € , elle fait parfaitement le job. Elle offre un upgrade très net , en attendant que mes moyens me permettent d'accéder à l'alimentation constructeur. Est ce que ce sera meilleur au point de justifier un prix 4 fois supérieur? Je ne suis plus pressé de tester :)))
De plus, les deux cables d'alimentation DC gx16 fournis avec la LPSU 200 sont basiques, et ce point est encore un axe d' upgrade intéressant .. J'attends un câble d'un fabricant spécialiste, qui devrait encore améliorer l'expérience. Je ferai volontiers un retour ici si je constate un gap.
Pour finir, j'ai eu un problème électrique indépendant de la LPSU200 lors de la mise en route, le service après vente audiophonics a été impeccable . Comme d'habitude. Bravo à toute l'équipe.
Super micro
Micro de mesure performant calibré à un prix raisonnable. L'intégration dans REW est sans souci
Laurent C.
Rapport Q/P excelleent
Placés sous des tablettes , afin de permettre d'isoler celles-ci du meuble, je peux profiter pleinement des qualités de ces support en bois de bouleau sous mes éléments, sans coloration du son.
Pour mon usage, c'est parfait.
ERIC C.
Aspect IEC audiophile
Très bon produit pour le prix et qui remplace allègrement une prise IEC standard et permet d'utiliser un câble de section bien supérieur.
ERIC C.
VIABLUE FILTER 16 Filtering Ferrite Reducer Ø16mm vers Ø15.5mm Viablue ferrite reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is essential for designing high...
Ferrite pour gros câble secteur
Excellent produit facile à installé sur du câble de grosse section grâce aux deux visses de serrage qui rentre dans la gaine et empêche la ferrite de coulisser.
Cyrille T.
Flat Cable USB-C Male to USB-C Male Angled 13cm This 13cm-long USB-C male to USB-C male flat cable lets you easily connect your phone to a portable battery or DAC, while minimising the space taken up by the cable. The cable...
Câble robuste. Utilisé sur ma moto routière qui à un port USBC Avec un logement exiguë, le câble est donc bien plié, mais reprend sa forme pas de marque de pliage. Pour les data c'est également bon utilisé sur ma Ledger.
Rudolf P.
Good choice
Good choice, with high price performance. Swiss build quality. Please mind the WBT 0114 sounds substantially better, at a price.
Rudolf P.
TUNG-SOL 6550 Power Tubes (Quad Matched) The Tung-Sol 6550 tetrode tube was developed for applications in the amplifier output stages of high fidelity bass amplifiers. It respects the construction of the original 1960...
Strong tubes
Have bought many samples, all test strong, highly recommended.
Fabien A.
Excellent Dac
Il y a déjà eu beaucoup d'avis et d'analyses sur ce DAC et je dois dire que je les partage.
Je possédais jusque la un DAC Gustard X16 qui me proposait déjà une restitution sonore d'un niveau très correct (notamment grâce à un changement de fusible judicieux) et j'ai malgré tout pu constater tous les apports du Cyan2 sur les différents points suivants:
Une sonorité plus riche avec beaucoup de matière dans le bas medium et un grave plus net et mieux défini. Une scène sonore large et détaillée et un son globalement plus dynamique.
Avant de me décider pour ce DAC, j'ai pu tester un R26 de Gustard, qui me parait avoir un son très très proche, sans un A/B testing je ne pourrais dire lequel est meilleur que l'autre et sur quels points.
Le fusible d'origine est très correct mais un changement pour un autre plus qualitatif semble une piste intéressante pour vraiment le libérer et qu'il puisse donner tout son potentiel.
John T.
LAIV AUDIO HARMONY UDDC Reclocker I2S Galvanic Insulation 768kHz DSD512 Black With the Harmony µDDC, Laiv Audio presents us a digital interface and reclocker that considerably reduces phase noise and jitter for a more natural sound rendering in an...
Brilliant device!
After long consideration I bouth the Laiv DDC. It made an amazing improvement in the sound. I am delighted. Just for the record, I feed the DDC
Siegfried F.
Ivan S.
IvanS
This is a truly exceptional piece of Hardware. The background sound is absolutely black to the point of incredible silence between passages or breaths. The tones and voices sound really true and the bass goes amazingly deep. Every instrument is exactly where it should be. Sometimes I find myself wanting to touch the musician's guitar because it is so precisely materialized in space.
I had borrowed an Eversolo DMP-A10 from a friend. It's a good machine but the Singxer outperforms it in all aspects.
I can only recommend it to everyone because after listening to it you will not think about replacing it for a long time.
Rumen S.
Excellent match!
This cable demonstrated perfect compatibility with systems featuring full-range speakers, particularly rear-loaded horns. Neutral, without exaggeration, and with a refined treble finish, the OYAIDE EXPLORER allows the drivers to reach their full potential. Highly recommended, especially for systems with single-ended tube amplifiers.
pascal P.
FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube...
Une merveille
Parfait à tous points de vue. Recul de bruit, distortion, dynamique tout est au top. Rapport qualité prix hallucinant. J'ai revendu mon préampli phono de grande marque à 200 € qui était loin derrière. Aucune hésitation pour ce produit. N'écoutez pas les forums qui disent que les tubes ne servent à rien : si , ils régulent la tension, même s'ils ne sont pas sur le signal. A quand un modèle mc ?
Impressionant...
Jusqu'alors, j'étais sceptique sur ce que pouvait apporter le traitement de l'alimentation électrique à un système audio. Pour mon système NAD C326 BEE / Davis acoustics Krypton 6 / câble Real cable TDC, 5mm2 dont je suis dans l'ensemble très satisfait, je trouvais des fois les basses un peu limites. Après avoir lu les différents avis, j'ai tenté le coup avant d'envisager plus précisément l'hypothèse d'un passage aux krypton 9 .
Bien m'en a pris ! Dès les premières secondes, j'ai ressenti les basses plus profondes et percutantes, sans en faire trop, exactement ce que je souhaitais, et une scène sonore plus élargie, plus riche, plus vivante, et ce pour une centaine d'euros !
Moralité : accessoire à tester, avant de système décider de changer !
joel V.
trés bon cable secteur
Paul V.
TOPPING LA90D Discrete Amplifier Class AB 2x120W / 1x180W 4 Ohm Silver Topping now offers the excellent LA90 in a version using discrete circuits, the LA90 Discrete. The result is a powerful amplifier with incredible metering for a breathtaking...
Topping LA90D power amplfier
I am very satisfied with the Topping LA90D power amplifier. I purchased four units to build an 8-channel active speaker setup. They are very solidly built and have a beautiful, professional appearance. The price-to-performance ratio is excellent. Their performance is outstanding. The measured specifications show exceptionally good results, with extremely low distortion figures. This results in a very pure sound without any coloration. In our opinion, this amplifier is highly recommended for use in a top-quality audio setup. The Topping LA90D performs as well as — and often better than — many other power amplifiers that are significantly more expensive.
Paul Vancluysen VCLLabs
Paul V.
AUDIOPHONICS WIRE Interconnect Cable RCA Male to XLR Male Stereo Gold Plated OFC Copper 1.5m (Pair) The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire RCA to XLR cable...
Very sastified about this product. Very flexible cable, high quality connectors. Good solid connection. In general, we have very good experience with produts made by Audiophonics Workshops.
Stephane M.
Installées sur un pré RIAA où les anciens tubes étaient devenus bruyants. Faible bruit de fond et ne semblent pas microphoniques.
Désolé, pas fait de mesures: Plug and play :)
Luboš W.
Rating
I use the power supply as a symmetrical power supply (2 pcs) to a low watt amplifier. It is almost noise free, no problems so far.
Johan v.
LB Aluminum Push Button with Blue Light 220V Ø12mm Silver 1NO type switch with blue indicator light. Operates from a bistable mechanism (two positions).  The connectors dedicated to the signal / power supply can support a voltage...
Good but small
Good switch but the button is small so not thumb size but more pinky sized
Johan v.
My favorite hook up wire
Easy to strip with a good stripper
Johan v.
Good quality easy to fit and solder
When soldering this type of terminal a good powerful soldering iron or station is helpful.
presque parfait
Les plus:
Le chargement et le palet presseur
Le silence total de fonctionnement et plutôt rapide
Le look et la taille compacte
La connectique très complète
Le surechantillonage fonctionne très bien
Les moins:
Une télécommande vraiment pas bonne lente,ultra directive
L impossibilité d accéder directement a une plage du cd
Si vous aviez l idée de l utiliser comme un mini streamer vous pouvez oublier. L appli est très mauvaise.
Johan v.
Good product
Good product good quality when soldering remove the nut to lower the thermal mass it makes soldering easier.
l argent a fait mon bonheur
Fantastique cable .précis détaillé pas tres loin d être analytique tempéré dans mon système haut rendement par le furutech violet qui prend le signal en charge a la sortie du monoceros. Il fait donc la liaison entre le holo spring 3 et le monoceros.
L alliance entre l argent du neotech et le cuivre du furutech me plaît bien.Monté sur xlr EIZZ
Jizhuang S.
HOLO AUDIO MAY LEVEL 2 Balanced R2R DAC and Independent Power Supply 32bit 1536kHz DSD1024 After 3 years of research and development to achieve a whole new level of performance and sound quality, HoloAudio introduces the MAY Level 2 discrete balanced R2R DAC! Flagship...
Holo Audio May 2
Je rajoutera la comparaison suivante qui me semble assez judicieuse, le Holo Audio May 2 correspond très bien au jeu du violoncelliste Pierre Fournier jouant sur des cordes en boyaux argent. Un jeu d'une élégance extrême, raffiné, aristocratique, mais un poil moins spontané que celui de Daniil Chafran ou de Jacqueline Du Près. Mais surtout ne pas penser que c'est un DAC HiFI, les émotions sont bien là, simplement elles ne sont pas jetées à la face de l'auditeur. Pour une personne à la recherche d'un DAC dont la signature sonore se rapproche des grands interprètes ( violon, violoncelle, piano, ... ) des années 1950, ce convertisseur est exceptionnel, même en comparaison à des DAC comme MSB, Esoteric et C°.
Jean-Michel P.
Déborde très peu de la face AV de l'ampli
Tout à fait satisfait.
Il a juste fallu que je ressorte le fer à souder, bien rangé depuis une dizaine d'années :)
