LB Aluminium Push Button with Blue Light 250V Ø16mm Black
1NO1NC type push button with blue indicator light. Operates from a monostable mechanism.
Reference : 17161
6,50 €tax incl.
5,42 € tax excl.
Shipping date: 23-05-2025.
PUSH BUTTON
1NONC 250V
LB Bouton Poussoir Aluminium avec Cercle Lumineux Bleu 9-24V Ø16mm Noir
The connectors dedicated to the signal / power supply are gold plated and can support a voltage of 250V / 3A. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 9 and 24V.
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Schéma bouton poussoir
1Connector PBT+GF20 (V0)
2H65 Silver / Gold plated pin
3Microswitch
4Contact: Silver tin oxide
5Base seat: V0 flame retardant
6Locking hook
7Non polar LED
8PC bushing, V2 flame retardant
9Latching mechanism
10PC, V2 flame retardant
11Silicon seal ring
12CNC button: Stainless steel/Aluminum
13Nickel plated hexagon nut
14Silicon seal ring
15H57/59 copper chrome plating, aluminum
Schéma bouton dimensions et câblage
Characteristics
Product typeMonostable push button 1NONC
Screw thread diameter16mm
Max panel thickness12mm
Total dimensions35*⌀21 mm
LEDColor: Blue
Voltage: 9-24V
Number of pins5
Voltage / Current250VAC / 3A
Mechanical life800000 cycles
Reference life40.000 hours
Operating temperature-30°C, +80°C
Insulation>= 1000mΩ
Dielectric strength1000VAC min
LED ColorBlue
Number of positions1
Button type1NO1NC
