Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Martin Å.
Great for the price!
Zacharias L.
Very good but...
Pavol B.
RCA Connectors
We offer a very wide range of RCA connectors. RCA plugs are essential in the audio industry, and are available depending on the material used, the plating applied, or the mode of use: crimp, solder, or clamp.
Among our many RCA connectors, discover the well-known brands such as Furutech, Elecaudio, Neotech, or 1877PHONO. A large choice of high quality RCA plugs, in OCC copper or pure silver.
