PSVANE 845-T-MII/2 Triode Power Tubes (Matched Pair)
PSVane 845-T-MII/2 tubes are high-quality triode power tubes that can be used in class A, B and C. The MKII range of tubes uses a PTFE base, ensuring high stability and excellent insulation. The amber-coloured anodised aluminium collar surrounding the PTFE base prevents corrosion and fingerprints while giving this tube a prestigious design. The tube also uses high-quality glass for increased durability.
By buying this product you get 42 loyalty points
Reference : 21012
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 11-11-2026.
3 >Month warranty
PSVane 845-T-MII/2 Triode Power Tubes (Matched Pair)
PSVane 845-T-MII/2 : Front view
Product typePower tube
Tube typeTriode
Number of pins4
Heater
Filament heating voltage (Uf)10V
Filament heating current (If)3.25A
Maximum Parameter
Anode operating voltages (Ua)1250V
Grid control voltage (Pa)75W
Output power (Pout)150W
Plate current (Ia)120mA
Interelectrode capacitance
Input6pF
Output6.5pF
From grid to plate14.5pF
Electrical parameter
Grid control voltage (Ug)-200V
Plate current (Ia)80mA
Mutual conductance (Gm)3mA/V
Amplification power (μ)5
Recommended load impedance (RL)3.4kΩ
Output power (Pout)15W
DimensionsØ64 x 185mm
PackageSold in pairs
Contacts number4
Tube typeTriode
PSVANE 845-T-MII/2 Tubes (Paire Appairée)
PSVane 845-T-MII/2 tubes are high-quality triode power tubes that can be used in class A, B and C. The MKII range of tubes uses a PTFE base,...
