This gold-plated RCA connector with 90° angle is ideal for DIY projects. The 90° angle is particularly practical for installations in confined spaces. This robust connector's aluminum body prevents interference. The gold plating on the contacts makes it resistant to oxidation and corrosion.
This RCA connector accepts cables up to Ø8mm in diameter. Assembly is quick and easy, since no soldering is required. The cable is also held securely to the connector.
| Specifications | |
| Product type | RCA connector |
| Max. cable diameter | Ø8 |
| Conductor material | Copper alloy |
| Conductor plating | Gold 24k |
| Body material | Aluminum |
| Angled connector | 90° |
| Mounting type | To screw |
| General | |
| Dimensions | 37 x 30 x 12mm |
| Color | Silver / Gold |
| Weight | 0.3kg |
| Package | 1x Gold-plated 90° angled RCA connector (sold by unit) |
| Max cable diameter (mm) | 8.0 |
| Connectic | Male |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
