[GRADE A] DD TC35C DAC AL5686 Male Lightning to Female Jack 3.5mm 32bit 384kHz
Refurbished product - Grade A
This TC35C DD adapter for smartphone is composed of a male Lightning connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of the audio signal for a clear and precise reproduction.
Reference : 17491
Refurbished
54,90 €tax incl.
45,75 € tax excl.
Brand new product. Original packaging is missing.
DD TC35C
Adapter DAC AL5686 Male Lightning to Female Jack 3.5mm 32bit 384kHz
DD TC35A Adaptateur DAC AL5686 Lightning Mâle vers Jack 3.5mm Femelle 32bit 384kHz
This TC35C DD adapter for smartphone is composed of a male Lightning connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
Be sure to plug in the headphones before connecting the DAC to the Apple device.
Product typeAdapter and DAC
Connectors1x Male Lightning
1x Female Jack 3.5mm
DAC ChipRealtek AL5686
Output power30mW @ 32Ω
Dynamic range> 110dB
THD+N< -92dB
SNR> 120dB
Dimensions16.6 x 16.2 x 9.6mm
Weight3.5g
InputLightning
OutputJack 3.5mm
DAC / ADC ChipAL5686
Max sampling rate384kHz
ColorBlue
ConnectorJack 3.5mm
ConnectorLightning
Refurbished GradeGrade A
Refurbished product - Grade A This TC35C DD adapter for smartphone is composed of a male Lightning connector and a female 3.5mm jack. It also...
