Refurbished product - Grade S
Brand new product. Old version: LD230CRA08 speakers
Subwoofer 500W (Unit)
The Rafale VR3-X kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases. Its bass-reflex load carries a 500Weff generative amplification coupled to three exceptional speakers with a diameter of 23cm. This exceptional trio has an equivalent emissive surface area to that of a 38cm and when necessary, the associated electronics allows a membrane excursion of +/-18mm ! With its many connection options, this box can be integrated without limitation into all major HiFi and Home Cinema installations. Capable of reaching absolutely amazing sound levels, even at the lowest notes, the VR3-X is the essential ally to make you experience the most beautiful and intense sensations!
Spécifications | |
Product type | Speaker kit |
Speaker type | Active subwoofer |
Load | Bass Reflex 90L |
Frequency response | 27Hz - 150Hz |
Power (RMS) | 500W |
Low level input | 2x RCA |
High level input | 2x Banana plugs 4mm / Direct tightening |
Cut out frequency | Adjustable from 38Hz to 150Hz |
Phase control | 0-180° |
Filtering slope | Adjustable 12dB-24dB-LFE |
Bass/Medium Speaker | LD230CRA08 (x3) |
Supply voltage | 115V / 230V |
Consumption | 700Wmax |
Dimensions | 320*830*530mm (W*H*D) |
Weight | 47kg |
