[GRADE A] BURSON AUDIO V7 VIVID PRO Single OPA (Pair)
-12%
Refurbished Product - Grade A
As an evolution of the V6 VIVID, the V7 VIVID Pro stands out for its clarity, precision and high dynamic range. It is particularly recommended for DAC output stages requiring a high level of transparency.
Reduced price!
Reference : 22729
Refurbished
119,00 €tax incl.
-12%
104,90 €tax incl.
87,42 € tax excl.
Last items in stock !
Shipping date: 24-11-2026.
Torn cardboard box.
Photo of the OPA Burson Audio V7 VIVID PRO
Burson Audio's OPA V7 features an 8-layer PCB that separates the signal path from grounding and shielding. This optimizes the signal path and offers additional protection against interference. With its V7 operational amplifier, Burson focuses on minimizing open-loop distortion, reducing noise levels, decreasing drift and achieving low offset. In addition, the SS Opamp V7 features extended bandwidth and versatile power supply compatibility, essential characteristics for outstanding analog audio amplification.
Burson Audio OPA comparison
V7 VIVID Pro: efficient heat dissipation
Burson's V7 operational amplifier is designed to operate at high temperatures. It features an aluminum shell for efficient heat dissipation. As a result, it can work with a higher quiescent current, greatly improving stability and audio quality.
Photo of OPA V7 Burson Audio
V7 VIVID Pro: how to identify and replace your operational amplifiers
To replace operational amplifiers, you must first determine whether they are double or single, and the correct installation position.
How to replace your OPA
List of OPAs compatible with the V7 VIVID Pro
Dual OPA: AD823, AD823AN, AD8066, AD8620, AD712, AD827, C4570, JRC4556AD, JRC4580, JRC5532, JRC5532D, JRC5532, LF353, LM4562, LME49860, LM833N, LME49720, MUSES8920, NE5532, NEC4520, NEC4570, NJM2068D, NJM2114, NJM2214D, NJM4558, NJM4558D, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832, BA15532.
Single OPA: NE5534, JRC5534, LT1122, TL071, OPA134, OPA627, AD811, AD829, AD844, OPA604, AD8610, AD711, AD797, LME49990, LME49710
Product typeSingle OPA
DesignDiscrete
Min. voltage±4V / 8 VDC
Max. voltage± 15V / 30VDC
Power consumptionSingle: 10mA
Dual: 20mA
Unity gain stable
Reverse voltage protection
Dimensions20 x 15.4 x 13.4mm
WeightSingle: 4.5g
Dual: 5.7g
Package2x Single OPA BURSON AUDIO V7 VIVID PRO
OPA TypeSingle
Refurbished GradeGrade A
Refurbished Product - Grade A As an evolution of the V6 VIVID, the V7 VIVID Pro stands out for its...
