Refurbished product - Grade A
Reconditioned by the manufacturer. Box of packing very slightly damaged.
High Definition IEM
Although the construction is fine enough to praise its space management (with the ergonomic advantage implied, IT-01 shine primarily by the quality of its electronic components.
Each channel has its dynamic Ø10mm transducer coupled to a Helmholtz resonator opening onto vent (bass-reflex).
The transducers were custom made to fit the exact specifications and the particular form-factor of these in-ear monitors. This greatly contributes to the excellent stability and dynamic finesse of rendering.
On each channel, the transducer is enhanced by a Helmholtz resonator opening onto vent (bass-reflex).
This design when used wisely in a rigorous construction, emphasizes the bass frequencies and reinforces the excellent frequency response ITE IT01.
The integration of this technology also reduces the mechanical stress on the motor, which allows a better definition of its dramatically reducing distortion.
The-ear headphones IT01 have a graphene membrane.
This material is ideal for outstanding lightness (comfort during long plays) as well as by its strength and durability.
To maintain the precision of the signal and to highlight the virtues of a player / amplifier nomadic quality, IT01 earphones come with a OFC copper cable handmade. The conductors are gold plated to maintain a stable and reliable signal between the transducer and the amplifier.
The cable is protected against twisting by a lightweight sheath which drastically reduces the weight of the connectors to avoid feeling tired or constriction that may alter the listening ease.
This translucent sheath leaves moreover appear quadruple yarn structure with a pleasant visual rendering.
Finally, this cable has been the subject of a microphone processing to significantly reduce the noise inherent in listening intra: movement / cable friction with clothes & hair, shocks, sway ... etc.
Type | In-Ear Monitor |
Frequency response | 10 Hz - 42 kHz |
Sensitivity | 108 dB (± 2 dB) |
Impedance | 16 Ω |
max | 10mW |
THD @ 1kHz 1mW | <1% |
Insulation | 26 dB |
Transducer / ear | x1 |
Transducer | Ø10 mm |
Cable | Removable |
conductors | MMCX - 3.5 mm jack gold plated |
Parts supplied | Earphones iBasso IT01 removable cable Storage Case 4x silicone tips (black) / pair 6x silicone tips (gray) / pair 2x foam tips shape memory |
