[GRADE B] EWEAT DMP20 Streamer WiFi DLNA AirPlay Bluetooth 4.2 32bit 768kHz DSD512 MQA
Refurbished product - Grade B
The Eweat DMP20 is a powerful and versatile network player, capable of playing many streams, whether your files are stored on a NAS, computer or smartphone connected to your network, or even on a local storage device. Its digital/analog conversion stage based on an AKM AK4493EQ DAC chip allows it to support high sampling rates, up to PCM 32bit 768kHz and DSD512 while offering a clear and rich sound reproduction
By buying this product you get 59 loyalty points
Reference : 16282
Refurbished
599,00 €tax incl.
499,17 € tax excl.
Some small scratches on the case.
Eweat DMP20
Eweat DMP20 Lecteur Réseau WiFi DLNA AirPlay Bluetooth 4.2 32bit 768kHz DSD512 MQA
The Eweat DMP20 is a powerful and versatile network player, capable of playing many streams, whether your files are stored on a NAS, computer or smartphone connected to your network, or even on a local storage device. Its digital/analog conversion stage based on an AKM AK4493EQ DAC chip allows it to support high sampling rates, up to PCM 32bit 768kHz and DSD512 while offering a clear and rich sound reproduction. This DAC is also associated with a USB interface XMOS XU216 capable of decoding audio files efficiently.
The Eweat DMP20 also offers the ability to decode and playback your MQA (Master Quality Authenticated) files, ensuring sound quality as close as possible to the original studio recording.
1ON/OFF LED Indicator
2Hard disk status indicator
3Volume button
4ON/OFF button
5IR Receiver
6Ethernet status indicator
7WiFi status indicator
8Power supply connector
9Balanced XLR output
10WiFi antenna
11Anti-theft lock slot
12Power supply voltage selector
13Single-ended RCA output
14USB-C input
15USB-A Host input
16Ethernet RJ45 input
17HDMI output (for connection to a TV or other screen)
18MAC address and serial number
Product typeStreamer
ConnectivityWiFi Dual Band 802.11 a/b/g/n 2.4G/5.8G
Bluetooth 4.1
Network protocolsDLNA
AirPlay
Roon
Samba
Inputs1x USB-C
1x USB-A 3.0 (USB Host)
1x Ethernet RJ45
1x Slot for 3.5" hard drive (max. 16TB) (hard drive not included)
Outputs1x Balanced XLR
1x Single-ended RCA
1x HDMI (GUI)
DAC ChipAKM AK4493EQ
CPUARM Cortex-A53 Quad Core
RAM2Go
Flash memory16Go
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
DxD up to 352MHz
Supported Bluetooth codecsaptX
Frequency response20Hz-20kHz (+0.002/-0.0023)
Dynamic range123dB
SNR123dB (20Hz-20kHz, A-Weighting)
Channel separation-136dB
Supported file formatsDSF, DFF, AIF, AIFF, ALAC, FLAC, M4A, MP4, WAV, APE, MP3, AAC, WMA, OGG, ASF
Supply voltage220-240VAC 50/60Hz
110-120VAC 50/60Hz
Housing materialAluminium
Total dimensions424 x 275 x 77mm
ColorFront panel : silver
Rest of the chassis : black
Refurbished GradeGrade B
Refurbished product - Grade B The Eweat DMP20 is a powerful and versatile network player, capable of playing many streams, whether your files are...
