By buying this product you get 134 loyalty points
Refurbished product - Grade S
Product in perfect condition.
This is the V1 version of the LPA-S400ET. Gain and buffer settings are therefore located directly on the unit's circuitry, under its cover.
This version operates on a 230V AC power supply.
Class D Stereo Amplifier Purifi 1ET400A 2x400W 4 Ohm
We are proud to offer you the Audiophonics LPA-S400ET, a Class D stereo power amplifier based on two Purifi 1ET400A modules. Similar electronically to the HPA-S400ET, this version is mounted in a more compact box making it easier to use in an environment where space is limited, its architecture also limits the length of the internal connections.
This ready-built and ready-to-use version is for audiophiles who want to equip themselves with a foolproof amplification solution, with a considerable power reserve as well as a perfect definition. PURIFI modules are among the most rigorous Class D amplification solutions on the market, with simply outstanding measured performance.
The package offers a high level of sound reproduction suitable for use with demanding loudspeakers, for large listening rooms or for studio applications requiring a large headroom without compromising on the accuracy and richness of the audio message.
All the components are integrated in a 100% Aluminium housing that is sober, robust, design and compact. This one has openings in order to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a rated power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by Hypex to provide the 2x64V voltage required to operate the most demanding amplifier modules.
This low-noise quality power supply meets the power requirements of the amplifier modules in every respect. In addition, the amplifier modules themselves have an excellent ability to reject supply noise. This makes the LPA-S400ET extremely insensitive to mains imperfections and voltage/current fluctuations that can cause interference noise.
The 2 modules are driven in phase opposition, to cancel the "Power-Supply Pumping" effect. This allows a greater stability of the power supply, distributing alternately on each rail the calls of current and thus increasing its capacities.
We have opted for a 2-level voltage regulation, to optimise the power supply to the OPAs and the auxiliary voltage supplied to the modules.
One Texas Instrument LM4562 OPA per channel is used. These are very low distortion OPAs offering the highest transparency with a very low THD. They are mounted on a DIP8 socket, allowing their replacement if needed.
To suit all uses, we have opted for 3 gain settings, selectable by jumper on the interface card :
Designed for easy integration, the LPA-S400ET has a balanced (XLR) and unbalanced (RCA) stereo input. Bipolar switches allow easy switching between input sources and even allow independent channel control.
On the output side, BP-207 carbon / 24k Ø5.5mm gold / carbon insulated terminals provide an excellent connection to the loudspeakers.
| Specifications | |
| Product type | Power amplifier |
| Power | 227W @ 8Ω, 1%THD 425W @ 4Ω, 1%THD 450W @ 2Ω, 1%THD |
| THD+N | 0.0007% @ PO=1W, f=1kHz 0.00026% @ PO=10W, f=1kHz 0.00015% @ PO=100W, f=1kHz 0.0007% @ PO=1W, f=20Hz-20kHz 0.00029% @ PO=10W, f=20Hz-20kHz 0.00017% @ PO=100W, f=20Hz-20kHz |
| IMD (CCIF) | 0.00025% @ PO=1W, f=18kHz+19kHz 0.00022% @ PO=10W, f=18kHz+19kHz 0.00027% @ PO=100W, f=18kHz+19kHz |
| IMD (DIM) | 0.002% @ PO=1W, DIM30 0.002% @ PO=10W, DIM30 0.002% @ PO=100W, DIM30 |
| Quiescent noise | 11.5µV (A-Weighted) |
| Dynamic range | 131dB @ 4Ω (A-Weighted) |
| SNR | 131dB @ 4Ω (A-Weighted) |
| Frequency response | 20Hz - 20kHz ±0.01dB @ RL=8Ω 20Hz - 20kHz ±0.01dB @ RL=4Ω 20Hz - 20kHz ±0.01dB @ RL=2Ω |
| Output impedance | Iout = 1A @ 0.07mΩ, 1kHz Iout = 1A @ < 0.65mΩ, 20Hz-20kHz |
| Input impedance | RCA : 47kΩ / XLR : 100kΩ Bypass : 2.2kΩ / 4.4kΩ |
| General | |
| Power supply | 230V (110V on demand) |
| Dimensions (without connectors) | 19 x 35.9 x 7.8cm |
| Weight | 3.17kg |
| Housing material | Aluminium |
| Color | Black |
| Power cable | Included |
| Input | XLR |
| Input | RCA |
| Output | Speaker terminal |
| Color | Black |
| Channel | Dual Mono |
| Class | Class D / T |
| Amplifier chip | Purifi 1ET400A |
| Power (W) | 400.0 |
| Refurbished Grade | Grade S |
