[GRADE S] AUDIOPHONICS XMOS U208 Digital interface USB I2S AES 2x TCXO OTG 24bit 192kHz
Refurbished product - Grade S
This interface based on the now famous XMOS U208 provides high level digital outputs in S/PDIF coaxial, optical, AES/EBU and I2S. USB has Asynchronous USB management.
Reference : 16259
159,54 €tax incl.
132,95 € tax excl.
Brand new product.
USB XMOS U208 Interface
24bit 192kHz
AUDIOPHONICS XMOS U208 Interface digitale USB AES I2S 2x TCXO OTG 24bit 192kHz
This interface based on the now famous XMOS provides high level digital outputs in S/PDIF coaxial, optical, AES/EBU and I2S. USB has Asynchronous USB management. This version offers an XMOS U208 interface combined with an integrated regulated linear power supply. Recognized without drivers under MacOS and linux this one requires a Windows driver (Click here). This model has a regulated linear power supply as standard and can be directly connected to the 220V. This digital interface is compatible with Audio-GD devices with RJ45 I2S or AES / EBU input.
USB interfaceXMOS U208
OTG Compatible
ClockTCXO 24.57Mhz
TCXO 22.57Mhz
12Mhz
Jitter4.6ps (2x TCXO)
Low noise regulated power supply(power cable not supplied)
CompatibilityRaspyfi, Volumio, piCorePlayer
Digital outputs1x Coaxial 75Ω : 24bit 192kHz
1x AES/EBU 110Ω : 24bit 192kHz
Optical Toslink : 24bit 192kHz
I2S via RJ45 : 24bit 192kHz
Housing material100% Aluminium
ColorBlack / Silver
Dimensions162 x 114 x 47mm
Weight0.9kg
Power cableNot included
Wiring diagram of I2S output on RJ45 connector
Pin 1 :DATA DSD A
Pin 3 :I2S LRCK DSD CLK
Pin 5 :I2S SCLK DSD B
Pin 7 :I2S MCLK
Pin 6 & 8 :GND MCLK
Pin 2 & 4 :GND
OutputI2S via RJ45
OutputOptical Toslink
OutputAES/EBU
OutputCoaxial SPDIF
Max sampling rate384kHz
Interface chipXMOS XCore U208
Refurbished GradeGrade S
Refurbished product - Grade S This interface based on the now famous XMOS U208 provides high level digital outputs in S/PDIF coaxial, optical,...
