Refurbished product - Grade A
Damaged packaging box.
The Douk Audio A5 Pro integrated amplifier, big brother of the A5, is a small amplifier based on audiophile components with a singular aesthetic. It's based on a TPA3255 amplifier chip and OPA NE5532, enabling it to deliver output power levels of up to 2x 120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly improves frequency response for accurate, authentic sound reproduction.
Compared with the A5, it offers a number of additional features, such as bass and treble tone control, and Bluetooth 5.1 reception for reliable, stable wireless transmission. The OPAs are DIP 8 mounted for quick and easy replacement. In terms of design, there's an attractive transparent glass that allows the operation to be carried out without dismantling the unit. This glass also allows use of the RGB LED display, which sublimates the amplifier circuit and can be adjusted via DIP switch.
On the rear panel, you'll find the essentials in terms of connectors, with an RCA input, a speaker terminal output and a 3.5mm AUX jack output, enabling you to set up a 2.1-channel system with an active subwoofer, for example. The front panel also features a 3.5mm headphone output, making the A5 Pro a perfect desktop amplifier.
The Douk Audio A5 Pro features a TPA3255 chip coupled with NE5532 OPAs. A PFFB (Post-Filter Feedback) circuit greatly enhances the amplifier's performance. With the 48V 5A power supply supplied, the A5 Pro is able to deliver up to 2x120W of power under a 4 ohm load. This power reserve makes it possible to provide sound for a relatively large space.
DOUK A5 Pro power table | ||
Power supply | Impedance | Output power |
32V 5A | ||
4Ω | 78W+78W | |
6Ω | 71W+71W | |
8Ω | 65W+65W | |
36V/6A | ||
4Ω | 107W+107W | |
6Ω | 100W+100W | |
8Ω | 94W+94W | |
48V/5A | ||
4Ω | 120W+120W | |
6Ω | 110W+110W | |
8Ω | 102W+102W | |
48V/10A | ||
4Ω | 250W+250W | |
6Ω | 210W+210W | |
8Ω | 185W+185W |
The front panel features a 3.5mm jack headphones output capable of delivering up to 500mW under 32 ohm. The Douk Audio A5 Pro can drive headphones and IEMs with impedances from 16 to 600 Ohm.
The Douk Audio A5 Pro's Bluetooth 5.1 function offers reliable, stable wireless transmission from a device such as your smartphone, for example. A practical feature for enjoying streaming applications quickly and easily.
The Douk Audio A5 Pro features 3 potentiometers on the front panel. One potentiometer adjusts the overall volume, and two potentiometers adjust the bass and treble tones, for a personalized sound according to the user's tastes and the file being played.
The NE5532 OPAs are DIP8-mounted, making them easy to replace. This is made even easier by the tempered glass window on the top of the amplifier. Here's a non-exhaustive list of OPAs that can replace NE5532s: 2134/2604/5532/2068/muse02 etc.
In terms of aesthetics, the A5 Pro boasts a tempered glass window on the top and LEDs that can be easily adjusted via DIP switch.
1 | Power ON-OFF / Source selector |
2 | 3.5mm jack headphones output |
3 | Bass control |
4 | Treble adjustment |
5 | Volume control |
6 | Bluetooth antenna |
7 | RCA input |
8 | AUX output 3.5mm jack |
9 | Speaker terminal output |
10 | 24V-48V power supply via DC jack |
Product type | Integrated amplifier Headphone amplifier |
Amplification chip | TPA3255 |
OPA | OPA5532 |
Input | 1x Stereo RCA Bluetooth |
Outputs | Speaker terminals 1x AUX jack 3.5mm output 1x 3.5mm jack headphones output |
Output power | 2x 120W @ 4 ohm (48V 5A) |
Recommended speaker impedance | 4-8 ohm |
THD+N | 0.003% |
SNR | ≥ 113dB |
Frequency response | 20Hz-20kHz (±0.7dB) |
Tone control | ±6dB |
RCA input sensitivity | 2V |
AUX 3.5mm jack output level | 3.7V |
Headphones output power | 500mW @ 32 ohm |
Recommended headphones impedance | 16-600 ohm |
Bluetooth version | Bluetooth 5.1 |
Power supply | DC 24-48V (48V 5A power supply included) |
Dimensions | 130 x 112 x 33mm |
Weight | 525g |
Color | Black |
Package | 1x Douk Audio A5 Pro 1x 48V 5A mains adapter |
Input | Bluetooth |
Input | RCA |
Output | Jack 3.5mm |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 120.0 |
Remote Control | No |
Refurbished Grade | Grade A |
