Refurbished product - Grade A
Torn cardboard packaging.
FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the K11 DAC/headphone amplifier. Based on an X2000 processor, it is compatible with network protocols such as Airplay 1 and Roon Ready, thanks to its WiFi 2.4/5GHz receiver. This means you can enjoy a wide range of digital sources, whether via your smartphone, your computer or a local network, from a NAS. Simple to use, this little device acts as a veritable gateway between your streaming services and your sound system. It features numerous digital outputs, including a USB-C output, a USB-A port (host and output), a coaxial SPDIF output and a Toslink optical output. The FiiO SR11 supports high-resolution PCM 32bit 768kHz and DSD DoP256 streams via its USB outputs.
Please note that the SR11 does not have a USB DAC function.
New V630 firmware available on FiiO.com
The FiiO SR11 supports the AirPlay network protocol, so you can easily connect your IOS devices. AirPlay supports streaming from Apple Music, FiiO Music, Spotify and Tidal. Roon Ready, meanwhile, gives you access not only to online services, but also to your music library on a local NAS server.
The multi-core X2000 processor provides real-time control of the SR11 and fast, stable audio signal processing with low power consumption.
The ethernet port supports speeds of up to 1000Mbps for smooth, fast transmission, while the WiFi module supports dual-band WiFi 2.4Ghz and 5Ghz for extremely stable wireless transmission without data loss.
The SR11's LCD screen displays essential operating information, such as selected mode, network status and volume level. The small potentiometer, also located on the front panel, enables a wide range of control actions. An infrared remote control is also supplied for remote control and an enhanced user experience.
FiiO's R&D team is proposing firmware updates for the evolution of the SR11 with new features: Bluetooth reception, FiiO Link, etc.
1 | USB-C power port (5V 2A DC) |
2 | USB-C output |
3 | Reset button |
4 | USB-A port (host and output) |
5 | WiFi antenna |
6 | Toslink optical output |
7 | Coaxial output |
8 | RJ45 Ethernet port |
Product type | Streamer |
Processor | X2000 |
WiFi module | AP6256 |
Ethernet transceiver | YT8531C |
Inputs | Network 1x USB-A Host |
Outputs | 1x USB-C output 1x USB-A output 1x Coaxial 1x Optical Toslink |
WiFi | 2.4G/5G dual band (802.11 b/g/n/ac) |
Ethernet speed | Up to 1000Mbps |
Supported network protocols | AirPlay 1 Roon Ready |
Supported sampling rates | USB: 32bit 768kHz, DSD DoP256 Optical Toslink / Coaxial: 24bit 192kHz, DSD DoP64 AirPlay reception: all streams are converted to 16bit 44.1kHz before output |
MQA support | On all outputs with fixed volume |
Digital output distortion | 0.000006% (0dB, 1kHz, 24bit 192kHz) |
Screen | LCD |
LED indicator | Blue: 48kHz and less Yellow: 48kHz and more Green: DSD |
MAJ Firmware | Via USB flashdisk (USB-A and USB-C) |
Power supply | 5V 2A DC via USB-C |
Dimensions | 157 x 133 x 32mm |
Weight | 375g |
Color | Black |
Package | 1x FiiO SR11 1x IR remote control 1x AC adapter with USB-A to USB-C cable |
Input | RJ45 |
Input | USB |
Input | WiFi |
Output | USB |
Output | Coaxial SPDIF |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Max sampling rate | DSD256 |
Max sampling rate | 768kHz |
Color | Black |
Remote Control | Yes |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | AirPlay |
Refurbished Grade | Grade A |
