WIIM PRO PLUS Streamer
Refurbished product - Grade A
The WiiM Pro+ is a compact, extremely versatile and high-performance audiophile streamer that transforms a conventional audio system into a connected system. It opens the door to music streaming via WiFi and Bluetooth 5.1, and is compatible with numerous transmission modes such as DLNA/UPnP, AirPlay 2, Google Chromecast, Alexa Music Cast, Spotify Connect and Tidal Connect.
Reference : 18742
249,00 €tax incl.
207,50 € tax excl.
Optical input cover does not close perfectly. Does not interfere with product use.
WiiM Pro+
Audio Streamer Bit-Perfect DAC AK4493SEQ WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz
WiiM Pro Lecteur Réseau Audio Bit-Perfect WiFi Airplay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz
The WiiM Pro+ is a compact, extremely versatile and high-performance audiophile streamer that transforms a conventional audio system into a connected system. It opens the door to music streaming via WiFi and Bluetooth 5.1, and is compatible with numerous transmission modes such as DLNA/UPnP, AirPlay 2, Google Chromecast, Alexa Music Cast, Spotify Connect and Tidal Connect. Several units can also be used in combination to set up a true multi-room system, with full remote control via the WiiM App mobile application or a voice assistant such as Alexa, Google Assistant or Siri.
The WiiM Pro+ is an improved version of the WiiM Pro, incorporating a better DAC and ADC as well as more efficient OPAs. Its performance, particularly with regard to its line input and output, has been revised upwards, with improved SNR and THD+N for even more accurate and transparent sound reproduction. The main improvements to the WiiM Pro+ are :
  • A better ADC for line input: WiiM Pro+ uses a TI Burr-Brown PCM1861 ADC, supporting 32bit 192kHz PCM streams at output, with an SNR of 110dB.
  • Ultra-low-noise clock, power supply and circuitry: The WiiM Pro+ features an ultra-low-noise clock and power supply and a PCB design optimised to achieve a THD+N of less than -110dB for the analogue output.
  • AKM DAC and TI OPAs for improved line output quality: A new-generation AKM AK4493SEQ DAC is now used to achieve a very low level of distortion and a wide dynamic range thanks to AKM Velvet Sound technology. This chip supports PCM streams up to 768kHz and DSD up to DSD512 while achieving an SNR of 120dB (A-wt) and a THD+N of -110dB.
  • Remote control: A voice remote control is now included, allowing you to control the WiiM Pro+ from the comfort of your sofa, without having to take out your phone.
WiiM Pro Plus
WiiM Mini
WiiM Pro
Ethernet
Yes
Yes
DAC
AKM AK4493SEQ
PCM5121
PCM5121
SNR analog output
121dB
106dB
106dB
THD+N analog output
-113dB (0.00023%)
-92dB (0.0025%)
-92dB (0.0025%)
ADC
Up to 24bit 192kHz
Fixed 16bit 48kHz
Fixed 16bit 48kHz
Chromecast audio
Yes
Yes
Grouping with Nest speakers and displays
Yes
Yes
Grouping with Echo speakers and displays
Yes
Yes
Yes
Alexa Multiroom with UHD
Yes
Yes
Grouping with HomePods
Yes
Yes
Yes
Alexa support
Yes
Yes
Yes
Google Support
Yes
Yes
Siri support
Yes
Yes
Yes
Grouping with WiiM or LinkPlay devices
Yes
Yes
Yes
AirPlay 2
Yes
Yes
Yes
AirPlay Cast
Yes
Yes
DLNA
Yes
Yes
Yes
Roon
Yes
Yes
Spotify Connect
Yes
Yes
Yes
TIDAL Connect
Yes
Yes
Yes
Gapless playback
Yes
Yes
Yes
10-band graphic equalizer
Yes
Yes
Yes
LinkPlay streaming platform
Yes
Yes
Yes
CPU
Quadcore A53
Dualcore A7
Quadcore A53
DRAM
512MB
128MB
512MB
Flash
512MB
128MB
512MB
Inputs
Line, Optical
AUX
Line, Optical
Outputs
Line, Optical, Coaxial
AUX, Optical
What is Bit-Perfect?
Bit-perfect is a term commonly used in audio. It is used to describe a player that can play a file without making any changes of any kind.
For example, if your player plays a 24bit/192kHz Hi-Res file on Qobuz, the digital output will propose 24bit/192kHz. Just like if the music file played is a 16Bit/44.1kHz, the digital output will propose 16Bit/44.1kHz, without any modification. A real 1:1 ratio (Input / Output).
This is what we call a real Bit-Perfect reading, as close as possible to the musical reality of the piece played.
Wiim Pro + : AirPlay 2, DLNA and Chromecast
The WiiM Pro+ supports the Apple AirPlay2 wireless transmission protocol, allowing you to not only easily stream your music from an Apple device, but also stream your music to multiple audio devices at once.
It also supports the DLNA protocol and integrates a Chromecast, allowing a wireless distribution of its music from the vast majority of connected devices.
WiiM Pro Lecteur Réseau WiFi Airplay 2 DLNA Chromecast Multiroom Bluetooth 5.2 24bit 192kHz
Wiim Pro + : Multiroom
The WiiM Pro+'s built-in multiroom feature allows you to stream your music throughout your home in 3 different modes. If you are using an Apple product, you can use Airplay 2 to set up your multiroom system. If you are using an Amazon product, you can use AVS (Alexa Voice Service) Multiroom technology. Finally, WiiM also provides an application to easily control your multiroom installation from your smartphone.
Wiim Pro + : Works with your voice assistant
The WiiM Pro+ is compatible with Amazon Alexa, Apple Siri and Google Assistant. This means you can easily control your network player via your voice assistant. Voice control can be done from your smartphone or from a HomePod, Amazon Echo or Google Home device (not included).
Wiim Pro + : Multiple audio sources
The WiiM Pro+ is compatible with many streaming services and web radios, such as Spotify, Tidal, Qobuz, Deezer, Amazon Music and TuneIn. You can enjoy your favorite music services and stream them wirelessly to your audio system. And if you want to connect other audio devices to your WiiM Pro, it has a stereo RCA input and a Toslink optical input.
WiiM Pro Lecteur Réseau Audio Bit-Perfect WiFi Ai<span id=
Wiim Pro PLUS : Spotify Connect & Tidal Connect
With the WiiM Pro+ you can stream your music directly from the Spotify Connect and Tidal Connect streaming services, without using the WiiM Home application.
Wiim Pro PLUS : AKM AK4493SEQ DAC
The WiiM Pro+ digital/analogue conversion stage uses an AKM AK4493SEQ DAC chip. This supports high-resolution streams up to PCM 32bit 768kHz and DSD512, but also offers very good sound performance, with an SNR measured at 120dB and a THD+N of -110dB.
Wiim PRO Plus : WiiM Home app
WiiM offers its free WiiM Home mobile app for iOS and Android to easily control all your WiiM devices connected to your network.
WiiM Pro Lecteur Réseau WiFi Airplay 2 Multiroom Bluetooth 5.1 24bit 192kHz
Wiim Pro PLUS : 10 bands EQ
With the WiiM Home application, you also get a 10-band graphic equalizer, allowing you to fine-tune the sound reproduction, depending on your listening style and your audio system. 24 preset EQ profiles are also available for quick and easy adjustment.
WiiM Pro Lecteur Réseau Audio Bit Perfect WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz
Wiim Pro PLUS : Gapless playback
With gapless playback, your listening experience is enhanced. The WiiM Pro+ uses two decoders to remove the gaps between the tracks at the beginning and end of each song and then combine them.
WiiM Pro Lecteur Réseau Audio Bit Perfect WiFi AirPlay 2 DLNA Chromecast <span id=Multiroom 24bit 192kHz
WIIM PRO + test by Audio Science Review
"The WiiM Pro Plus is a high-performance streamer with a perfectly matched DAC, equalizer and analog input. The Plus version greatly enhances its performance. The software demonstrates impressive depth and capability."
Test WIIM PRO + Audio science review
Product typeStreamer
InputsWiFi
Bluetooth 5.1
1* Ethernet RJ45
1* Optical Toslink
1* Stereo RCA
OutputsBluetooth 5.1 A2DP Sink
1* Stereo RCA
1* Coaxial
1* Optical Toslink
1* Trigger 12V on Jack 2.5mm
Wireless connectivityWiFi 2.4G/5G IEEE 802.11b/g/n/ac
Bluetooth 5.1
Chromecast
Supported audio codecsMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Suppported streaming services and webradiosSpotify
Deezer
Qobuz
Amazon Music
Tidal
Pandora
Napster
Apple Music
TuneIn
iHeartRadio
LinkPlay Radio
Spotify Connect
Tidal Connect
Supported network protocolsSpotify Connect
Tidal Connect
Amazon Music Cast
AirPlay 2
DLNA
Chromecast
Supported output sampling ratesPCM 24bit 192kHz
Bit-Perfect
Gapless playback
EQ10 bands
24 presets
DAC chipAKM AK4493SEQ
ADC chipTI Burr-Brown PCM1861
Line output levelMax 2.1V RMS
SNR120dB
THD+N (line out)0.0004% (-108dB)
Supply voltage5VDC 2A via USB-C
Dimensions140*140*41mm
Weight320g
Package1* WiiM Pro
1* Power adapter
1* Voice remote control
1* USB-C cable
1* RCA cable
1* Optical cable
InputRJ45
InputWiFi
OutputOptical Toslink
OutputCoaxial SPDIF
OutputBluetooth
DAC / ADC ChipAK4493SEQ
Max sampling rate192kHz
Remote ControlYes
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Refurbished GradeGrade A
[GRADE A] WIIM PRO+ Audio Streamer Bit-Perfect DAC AK4493SEQ WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz
Refurbished product - Grade A The WiiM Pro+ is a compact, extremely versatile and high-performance audiophile streamer that transforms a...
