LT3045 LT3094 +/-5VDC
This dual regulated linear power supply module provides a clean and stable DC electrical signal with a noise level close to 0 by using a positive LT3045 Ultrahigh PSRR linear low-noise regulator and its negative equivalent, the LT3094. The module allows a choice of AC or DC input over a wide voltage range. The output, from +/-2.5VDc to +/-15VDC, is either on a 2.54mm XH connector or on a screw terminal block.
The output voltage is variable. The basic setting is +/-5VDC. To adjust the output voltage, it is necessary to unsolder two resistors to weld two others of different values:
| Specifications | |
| Product type | Linear power supply module |
| Inputs | AC on screw terminal DC on XH 2.54mm connector |
| Outputs | DC on XH 2.54mm connector DC on screw terminal |
| AC input voltage | 2x5VAC to 2x20VAC (AC-0-AC) |
| DC input voltage | +/-5VDC to +/-28VDC |
| Output voltage | +/-2.5VDC to +/-15VDC |
| RMS Noise | 0.8uVrms (10Hz to 100kHz) |
| PSRR | 76dB @ 1MHz |
| Output current | 500mA |
| General | |
| Dimensions | 88 x 46mm |
| Fixation holes spacing | 80 x 39mm |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 2.5 |
| Output current (A) | 0.5 |
| Input voltage (V) | 5.0 |
| Input voltage (V) | 15.0 |
| Input voltage (V) | 25.0 |
| Input voltage (V) | 10.0 |
| Input voltage (V) | 20.0 |
| Input voltage (V) | 28.0 |
| Power Supply | Regulated Linear Power Supply |
