IAN CANADA LINEARPI PRO Pi5SE Ultra Low Noise Linear Power Supply Module
The Ian Canada Linear Pi Pro Pi5SE is an ultra-low noise linear power supply module delivering high-quality, high-current power that is both versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application, offering a noise level of only 0.8µV. Multiple LinearPi modules can be combined to create a larger power supply system. This module can also be easily upgraded to a supercapacitor power supply by combining it with the IanCanada UcConditioner.
Reference : 21370
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 03-04-2026.
Ian Canada Linear Pi Pro Pi5SE Ultra-Low Noise Linear Power Supply Module 12V / 5V / 3.3V 5A
Ian Canada Linear Pi Pro Pi5SE : Front view
Many users fail to power the Raspberry Pi 5 via GPIO with conventional linear power supplies: the LED remains red and requires pressing the power button to start. This incompatibility stems from the specific startup requirements of the Pi 5, which render most low-noise linear power supplies unusable despite their ability to deliver 5A.
The LinearPi Pro Pi5SE resolves this technical limitation by natively meeting the Pi 5's initialisation criteria. With this special edition, the LED turns green immediately and the system starts up automatically without manual intervention. This power supply retains the option of integrating a UcConditioner/Pro module to further optimise performance.
Product typeLinear power supply module
Output voltage12V DC
5V DC
3.3V DCV
Output current5A
Recommended input voltage3.3V configuration: 5VDC
5V configuration: 9VDC
12V configuration: 15VDC
Noise0.8µV
Transformer recommendation chart
Voltage configurationWorking currentTransformer P/N or equivalent
3.3V0-5A1182Q6
0-2.5A1182N6 ou 1182L6
5V0-5A1182Q6
0-2.5A1182N6 ou 1182M9
12V0-3A1182M12 ou 1182P12
0-2A1182L12 ou 1182M12
Dimensions132 x 56mm
Mouting holes spacing114.5 x 49mm
Package1x Ian Canada Linear Pi Pro Pi5SE
1x PCB cable
InputScrew terminals
OutputScrew terminals
OutputUSB
Output voltage (V)5.0
Output voltage (V)3.3
Output voltage (V)12.0
Output current (A)5.0
Input voltage (V)5.0
Input voltage (V)15.0
Input voltage (V)9.0
Power SupplyLinear
IAN CANADA LINEARPI PRO Pi5SE Ultra Low Noise Linear Power Supply Module 12V / 5V / 3.3V 5A
The Ian Canada Linear Pi Pro Pi5SE is an ultra-low noise linear power supply module delivering high-quality, high-current power that is both...
