By buying this product you get 41 loyalty points
The UcPure Pro from Ian Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance. Because it is a pure passive power supply, there will be neither feedback nor active components involved when it’s turned on. At the pure mode, the output is 100% isolated from input, only the pre-charged ultracapacitor pack will be connected to the load.
UcPure Pro revolutionary employs triple PCB architecture to separate the management PCB from the ultracapacitor pack PCBs. The output will be taken directly from the ultracapacitor pack without charging or other circuits involved. Bolt-down automotive fuses are first time being used by UcPure Pro for higher reliability and lower ESR.
UcPure Pro could be the best low noise, low ESR pure power supply in world so far. Sound quality of sensitive audio applications such as low jitter clock oscillators, DACs, FIFOs, I/V stages and many other circuits will be benefited greatly from this UcPure Pro power supply.
Please note that supercapacitors are sold separately.
Product type | Supercapacitor power supply module |
Input voltage | 15V AC for 12V configuration or 15V to 19V DC |
Output voltage | 12V |
Compatible capacitors | XL60-2R7308T-R ou TPLH-2R7/3000SL60138 for all configurations except 12V XL60-3R0308T-R ou TPLH-3R0/3000SL60138 for 12V and all other configurations |
Package | 1x Ian Canada UcPure Pro 43B (12V) |
Input | Screw terminals |
Input | Jack DC 5.5/2.5mm |
Output | PCB Connector |
Output | Screw terminals |
Output voltage (V) | 12.0 |
Output current (A) | 10.0 |
Input voltage (V) | 15.0 |
Power Supply | Ultracapacitor power supply |
