LDOVR TPS7A4700 Ultra Low Noise Regulated Linear Power Supply 1.4V / 20.5V 1A
This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input voltage range is from 3 to 25VDC or 3 to 18VAC. Its output is adjustable in 0.1V steps, from 1.4V to 20.5V 1A, using solder pads on the PCB.
Reference : 16285
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 16-07-2025.
LDOVR TPS7A4700
LDOVR TPS7A4700 Module Alimentation Linéaire Régulée Ultra Faible Bruit 1.4V / 20.5V 1A
This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input voltage range is from 3 to 25VDC or 3 to 18VAC. Its output is adjustable in 0.1V steps, from 1.4V to 20.5V 1A, using solder pads on the PCB:
LDOVR TPS7A4700: Output voltage adjustment diagram
Please set the desired voltage before soldering the rail to the PCB.
Product typeRegulated linear power supply
Input supply voltage3VDC to 25VDC
3VAC to 18VAC
Any-Out™ voltage modesUser programmable output via solder pads on the PCB
Output voltage range : 1.4V to 20.5V (0.1V step)
Output current1A
Output noise4µVrms (10Hz, 100kHz)
Ripple rejection82dB (100Hz)
≥55dB (10Hz, 10MHz)
Dropout voltage307mV @ 1A
ProtectionsFixed current limit
Thermal protection
Operating temperature voltage-40°C / +125°C
External feedback option
PCB Dimensions30 x 60mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)20.5
Output voltage (V)1.4
Output current (A)1.0
Input voltage (V)3.0
Input voltage (V)25.0
Power SupplyRegulated Linear Power Supply
Manque d 'info
Cette carte doit sûrement valoir le coup. Je ne le sais pas car l'opération de montage de la carte de régulation ainsi que le pontage des pins a souder sont délicat a faire pour un neofite en soudure électronique. Prévoir un fer très fin vu le peu d' espace qu'il y a. La mienne n' a pas supporter mon manque d' experience.
This review has been posted for LDOVR TPS7A4700 Ultra Low Noise Regulated Linear Power Supply 1.4V / 20.5V 1A
This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input...
