LHY AUDIO Linear Power Supply Module LT3042 5V 1.5A
This LHY Audio linear power supply module offers a very nice design quality, using a LT3042 voltage regulator to provide a clean and stable electrical signal. The module can be powered in AC or DC. It delivers an output voltage of 5V and a current of 1.5A with a very low noise level.
4.5 / 5
Reference : 17275
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 10-10-2025.
To help you choose the right power supply for your projects, we invite you to visit this page
LHY Audio Linear power supply module
LT3042 5V 1.5A
LHY Audio Module d'alimentation linéaire LT3042 5V 1.5A
Product typeLinear power supply module
Input voltage3.3-20VDC
3-13VAC
Output voltage5V
Output current1.5A
RMS noise0.8µVrms (10Hz-100kHz)
PSRR79dB à 1MHz
Voltage regulatorLT3042
Dimensions (L*P*H)82*39*29mm
Mounting holes spacing75*32mm
InputSolder pad
OutputSolder pad
Output voltage (V)5.0
Output current (A)1.5
Input voltage (V)3.0
Input voltage (V)3.3
Input voltage (V)20.0
Input voltage (V)13.0
Power SupplyRegulated Linear Power Supply
4 reviews
Very Good
I use it for ES9019K2M Audiophonics Dac Board.
This review has been posted for LHY AUDIO Linear Power Supply Module LT3042 5V 1.5A
Parfait pour mon kit DAC.
Je le sollicite entre 300 et 400mA et le dissipateur est aux alentours de 45°C.
Il faut probablement le ventiler si vous demandez 1.5A.
Je cherchais une alimentation faible bruit et elle convient parfaitement. J'ai un bruit mesuré à l'oscilloscope, en charge ( à 324mA) d'environ 4mVpp, avec un condensateur de 4700uF Gold Tune derrière. (Mon ancienne alimentation à découpage avait un 5V +- 115mVpp dans la même configuration).
J'alimente un module DAC ES9018K2M.
The supplied heatsink is waaaay too small
Even when powered by as little voltage as 6.5V AC, the heatsink gets extremely warm. Delivering 0.7A (@ 5VDC) of constant current, which less than 50% of rated max current (1.5A), the heatsink instantly heats up to 60'C in a well ventilated area.
 (3)
This LHY Audio linear power supply module offers a very nice design quality, using a LT3042 voltage regulator to provide a clean and stable...
