LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8
The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8 network players by replacing the original switching power supply. The LPS-A8, manufactured by LHY Audio, provides the streamer with improved performance.
By buying this product you get 35 loyalty points
Reference : 19891
359,00 €tax incl.
299,17 € tax excl.
This product is temporarily unavailable.
LHY Audio LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8
LHY Audio LPS-A8 : Top view
Removing or changing the power supply of the EverSolo DMP-A8 invalidates the warranty.
LHY Audio LPS-A8: Linear power supply
First of all, the LPS-A8 power supply from LHY Audio has the immense advantage of being a linear power supply, which has several advantages over the original decoupled power supply. Firstly, because of the way it works, this type of power supply generates no high-frequency noise, making it naturally quieter and easier to filter. Furthermore, this type of power supply tends to offer a much more stable output voltage with very little fluctuation or ripple, an essential quality in power supplies for HiFi equipment that is very sensitive to this type of disturbance.
LHY Audio LPS-A8: Low-noise power supply
In order to offer the quietest possible power supply, LHY's LPS-A8 incorporates two LT3042 ultra-low-noise voltage regulators in a symmetrical architecture, ensuring a noise floor of less than 10μV.
LHY Audio LPS-A8: Triple shielding of the toroidal transformers
Again with a view to offering the cleanest possible power supply, the two toroidal transformers are triple-shielded, protecting them from environmental EMI noise while preventing the magnetic field of the transformers from impacting on the audio signal.
LHY Audio LPS-A8: Non-destructive modification
Finally, it's important to note that changing the EverSolo DMP-A8 power supply is non-destructive. In fact, LHY offers a fixing system identical to the original power supply, so you can simply replace it without having to adapt the frame.
Type of productLinear power supply kit for EverSolo DMP-A8
Noise levelNo load : < 10μV
80% load : < 30μV
Supply voltage220-240V AC
Transformer typeIron core
OFC copper winding
Dimensions170 x 72 x 45mm
Package1x LHY Audio LPS-A8
2x 6P cable
1x Screwdriver
1x Allen wrench
1x Pair of gloves
InputNC
OutputNC
Output voltage (V)NC
Output current (A)NC
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
3 reviews
Qualitatif
Aussitôt reçu, aussitôt installé dans mon lecteur Eversolo A-8, Le module respire la qualité, c'est livré avec les outils, et les gants blancs. 10 minutes pour le mettre en place est largement suffisant, c'est à la portée de n'importe qui. Au niveau de l'apport qualitatif à l'écoute, sincèrement, je n'ai pas senti de différence audible, mes oreilles ne sont peut être pas à la hauteur.
Vidéo d'installation sur Youtube
This review has been posted for LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8
Aide au montage kit
Une (voire plusieurs) vidéo de montage existe sur YouTube dont celle-ci : https://youtu.be/EMOg57Ogp2M?si=zPhZQrFUvQWlmw92
Excellent
Se monte très facilement, matériel top qualité, reste à juger la différence au niveau de l'écoute...
Il existe une vidéo de montage destinée au modèle DMP-A6 mais qui se transpose, bien respecter les précautions indiquées, notamment en ce qui concerne l'ouverture du capot face avant.
The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8...
