The Dayton Audio AXIS-R is a wired remote control designed to provide quick access to the essential functions of the AXIS-8 DSP without opening its software. From the listening position, it lets you adjust the volume or switch between saved presets, simplifying everyday control of an audio system in the car or at home.
Once the DSP is configured, the AXIS-R gives direct access to the most frequently used controls, without requiring a phone, tablet or computer. Its wired connection ensures operation independent of mobile devices and allows the system to be adjusted from a location suited to its use: within reach of the driver in a vehicle or near the listening area in a home installation.
The 3m cable makes it easy to position the remote control in most car and home installations. If additional length is needed, a standard RJ45 extension cable can extend the connection and route the cable to the desired location.
The removable mounting bracket allows permanent or temporary installation in a vehicle, on a desk or near the listening position. It can also be removed to use the remote control without a bracket, while its metal construction is designed to withstand everyday handling.
Technical specifications
| Specifications | |
| Product type | Wired remote control |
| Compatibility | Dayton Audio AXIS-8 |
| General | |
| Dimensions | 104 x 38 x 22mm |
| Weight | 128g |
| Color | Black |
| Package | 1x Dayton Audio AXIS-R 1x RJ45 cable 3m 1x Mounting plate |
