This Cat7-standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable with a diameter between 5.8 and 8mm. Furthermore, to reduce any potential interference, this connector is shielded using a zinc alloy.
Product type | Ethernet RJ45 male connector |
Ethernet category | Cat 7 |
Min / Max cable diameter | 5.8mm - 8mm |
Min / Max conductors section | 0.205mm² - 0.326mm² (22-24AWG) |
Body material | Phosphor bronze |
Shielding | Nickel |
Dimensions | 14 x 55 x 12.6mm |
Color | Silver |
Package | Sold by unit |
Max cable diameter (mm) | 8.0 |
Mounting type | To connect |
Connectic | Male |
Connector | RJ45 |
Contacts Material (Connector) | Phosphor Bronze |
Contacts Plating (Connector) | Gold |
