Refurbished product - Grade BBehind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you to stream your music from the Internet to your DAC, without any loss of quality. Hi-Res certified and capable of playing streams up to PCM 32bit 384kHz and DSD256 via WiFi / LAN, you just need to associate a...
Refurbished product - Grade BThe Ikko ITM05 is an ultra-portable balanced headphone amplifier and DAC combo, integrating high quality components in an extremely compact and lightweight format. It's the perfect companion for your smartphone to give you the best sound experience wherever you are. Practical, it slips easily into a pocket or bag.
Refurbished product - Grade BContinuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this family. Thanks to its highly efficient Class D architecture, it can easily be integrated into a system, providing significant power to your speakers.
Refurbished product - Grade BAir coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low...
Refurbished product - Grade BThe Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
Refurbished product - Grade BMost electrostatic headphones offer excellent musical potential, but their performance is often limited by the associated headphone amplifier. The Topping EHA5 electrostatic headphone amplifier helps your headphones to reach their full potential, with detailed and dynamic sound reproduction.
Refurbished product - Grade SThis stable, robust 6N3 / 2C51 tube will add warm tones to your sound once it has been integrated into the amplification stage of your HiFi equipment. It is made up of 9 poles and will therefore fit easily into a Noval support (9pin). It can replace tubes such as the 5670, 6H3, 6H3N or 396A.
Refurbished product - Grade SThe ETI Link Spade offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good conductivity level (IACS 95) and a perfect resistance to oxidation. The body of the connectors is made of aluminum, both robust and protecting the signal from...
Refurbished product - Grade SFerrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the essence of your music. With very low distortion, impressive dynamics and an incredible level of detail, the OOR is the ultimate companion for...
Refurbished product - Grade SWith the KA2, FiiO offers a powerful and affordable portable DAC and headphone amplifier combo, allowing you to enjoy the best possible sound quality both on the road and at home. The KA2 features a dual DAC conversion stage and an optimized architecture to deliver accurate and dynamic sound.
Refurbished product - Grade S2.65m long pre-cut cableThis premium limited edition Furutech FP-S55N power cable has been designed with the utmost care and the best components and techniques to allow your audio system to deliver its full potential and your music to express itself in the most beautiful way. As the AC power supply is the starting...
Refurbished product - Grade SThis high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio signals to improve the sound quality of a HiFi system. The C18 is equipped with an ultra-low noise oscillator.
Refurbished product - Grade SThe AP80 Pro-X from Hidizs is a compact and powerful digital music player, benefiting from both a neat design and quality components. Behind a 2.45" IPS touch screen are two ESS ES9219C DACs, a powerful FPGA, a Bluetooth chip and a large battery. The AP80 Pro-X is as versatile as it is efficient in terms of sound reproduction.
Refurbished product - Grade SThis high frequency toroidal transformer has a double primary winding of 50V 1-100kHz. Its secondary windings deliver 2x 500V 2A for a power of 2000VA.
Refurbished product - Grade SiBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS ES9038Pro chip, supporting high resolution audio streams, up to PCM 32bit 768kHz, DSD512 and MQA 16x, while ensuring an impressively clear and rich...
Refurbished product - Grade SThis 15 pins interconnecting ribbon cable with a length of 25cm is ideal for DIY projects, allowing a quick and easy assembly. It is perfectly adapted to connect different modules together.
Refurbished product - Grade SThe Shanling EC3 is a CD player that stands out at first glance thanks to its compact size with measurements of only 188mm wide by 255mm deep and 68mm high. A certain compactness and yet incredible performances thanks to an intelligent and particularly careful design. Thanks to its know-how, Shanling offers a player that will...
Refurbished product - Grade SWith the Shanling H2, the Shanling brand unveils a compact, versatile device that performs the functions of portable DAC and headphone amplifier with integrated player. It features high-quality components such as a Cirrus Logic CS43198 DAC chip, a second-generation XMOS XU-216 USB interface, an Ingenic X1000 processor and...
Refurbished product - Grade SThe 6L6WXT+ power tube is based on the vintage RCA 6L6GC design. However, it features larger plate dimensions and an improved grille structure for better power handling. It also features mica spacers with metal springs to eliminate noise and microphony.
Refurbished product - Grade STHIEAUDIO Hype 10 (HYPE for Hybrid Performance) are a pair of high-end in-ear monitors from the brand's Hype series. These earphones use 10 Balanced Armature drivers for treble, midrange and bass, as well as IMPACT² technology consisting of 2 x 10mm diaphragms for infrabass.
Refurbished product - Grade SThe Topping Hane in-ear monitors from the Arpegear series are dynamic IEMs equipped with a Ø10mm DLC (Diamond-like Carbon) diaphragm. True to its reputation, Topping offers here a product with remarkable performance, such as a THD of less than 0.05% (@ 90dB SPL), and a frequency response curve guaranteeing sound...
Refurbished product - Grade SThe Topping DX7 Pro is a model of versatility and performance. This DAC embeds a particularly complete connectivity, covering the vast majority of possible integrations in a HiFi audio system, combined with an intelligent architecture supporting high sampling rates and offering rich and accurate audio reproduction.
Refurbished product - Grade SThis high quality toroidal transformer delivers a power of 750VA with three secondary windings of 9V 27.7A each. The primary winding has a voltage of 380V 50HZ.
Refurbished product - Grade SParticularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
