AUDIO-GD MASTER 9 Preamplifier / Amp Balanced Pure Class A RCA XLR ACSS
The Audio-GD Master 9, both preamplifier, headphone amp, provides exceptional musicality and unrivaled in this price range.
KEY POINTS:
  • preamplifier
  • Headphone Amp
  • symmetrical
  • Class A
  • ACSS
Reference : 8509
1 649,00 €tax incl.
1 374,17 € tax excl.
Including 1,00 € for green tax
AUDIO-GD MASTER 9
Preamplifier / Headphone Amplifier / Symmetry
Audio-GD MASTER-9
Very high fidelity ...
The MASTER 9 of audio-GD is the new flagship of the brand, it will give you a musicality totally unmatched in this price range. It is thus logically intended to become a preamplifier / headphone amplifier cult in the history of Mr. He Qinghua's firm.
You can find a complete test (In English) of this device out of the ordinary:Audio-GD MASTER 9 Review - HeadMania.
Connectivity for all configurations
It has no less than 5 analog inputs for all needs: 2x RCA / 2x XLR / 1x ACSS. The "preamplifier" outputs are in RCA, XLR or ACSS, and the headphone output stage consists of an XLR 4 PIN, two XLR 3 PIN, and a 6.35mm jack output. The result: great musicality thanks to an exceptional dynamics and an extremely detailed rich sound.
Audio-GD Master-9
Class A
Class A
A Class A amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thereby limiting harmonic distortion on the output signal. The signal coming out of the MASTER 9 is therefore of excellent quality, due to the absence of this famous distortion of crossing of the alternations of the sinusoids./ P>
ACSS Technology
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and know-how of the brand, this technology offers a less colored sound, more detailed, and a neutrality without equivalent. Every engineer of the firm is, in addition to being experienced, a passionate of HiFi and Audio like you and us. Namely, when the ACSS output is used, the outputs XLR and RCA switch to MUTE
ACSS
THD<0.002%
XLR GainLow gain 16dB / High gain 20dB
SNR> 130dB
Volume control100 not exponential
Headphone output level (low power)40 Ohm (9000mW) / 100 Ohm (3800mW) / 300 Ohm (1250mW) / 600 Ohm (630mW)
Niveto the amplifier output (high power)40 Ohm (2500mW) / 100 Ohm (1050mW) / 300 Ohm (350mW) / 600 Ohm (175mW)
Preamplifier output level (max RMS)10V (RCA) / 20V (XLR) / 4.8mA (ACSS)
Input / output impedance1 Ohm / 90K Ohm (XLR) / <10 Ohm (ACSS)
crosstalk> 130dB
Power135W
Various
Consumption55W
WeightAbout 16kg
Housing material100% Aluminum
Dimensions430 x 430 x 93mm
AccessoriesPower cable
InputACSS
InputXLR
OutputACSS
ClassClass A / AB
Produit au top !
Bonjour,
Impressionnant. Audio Gd fait des produits d'un exceptionnel rapport qualité/prix et ce pré-ampli casque en est encore la preuve. Idéal avec mon DAC Master 7 mais il s'associera sans problème avec d'autres équipement car il est neutre. J'espère pouvoir m'acheter un ampli Master 3 dans quelques mois...
 (3)
This review has been posted for AUDIO-GD MASTER 9 Preamplifier / Amp Balanced Pure Class A RCA XLR ACSS
The Audio-GD Master 9, both preamplifier, headphone amp, provides exceptional musicality and unrivaled in this price range. KEY POINTS:...
