SHANLING M7T Digital Audio Player DAP Gray
-17%
The Shanling M7T digital audio player is based on audiophile components and an Android 13 operating system. It features two AKM AK4498EX DAC chips, an AK4191 Delta Sigma modulator, and a USB-XMOS interface for digital-to-analog conversion. The headphone amplification section is based on Muses8920 and BUF634 OPAmps combined with JAN6418 tubes. This combination of components gives the Shanling M7T the ability to support sampling rates up to PCM 32-bit 768kHz and DSD1024 while delivering up to 900mW @ 32 Ohms of power, allowing it to drive many headphones and IEMs.
Reduced price!
Reference : 21099
1 190,01 €tax incl.
-17%
990,01 €tax incl.
825,00 € tax excl.
SHANLING M7T Digital Audio Player DAP Snapdragon 665 2x AK4498EX Bluetooth WiFi 32-bit 768kHz DSD1024 Android Gray
Photo du SHANLING M7T
The Shanling M7T digital audio player is based on audiophile components and an Android 13 operating system. It features two AKM AK4498EX DAC chips, an AK4191 Delta Sigma modulator, and a USB-XMOS interface for digital-to-analog conversion. The headphone amplification section is based on Muses8920 and BUF634 OPAmps combined with JAN6418 tubes. This combination of components gives the Shanling M7T the ability to support sampling rates up to PCM 32bit 768kHz and DSD1024 while delivering up to 900mW into 32 Ohms, allowing it to drive many headphones and IEMs.
The device runs on Android 13, supported by a Snapdragon 665 processor for a smooth and enjoyable user interface. It also features Bluetooth with support for aptX and aptX HD high-definition codecs for stable wireless transmission. A 7000mAh battery makes it the perfect everyday companion.
In terms of connectivity, it also has a USB-C charging/input port and two headphone outputs: a single-ended 3.5mm jack and a balanced 4.4mm jack. It should be noted that the 3.5mm jack output is Mini SPDIF compatible for greater DAP usability.
Product typeDigital audio player DAP
Puce DAC2x AK4498EX with AK4191
USB interfaceXMOS
AOPMuses8920 + BUF634
TubesJAN6418
ProcessorSnapdragon 665 (6GB Ram, 128GB ROM)
Inputs1x USB-C
Bluetooth
WiFi
Outputs1x Balanced 4.4mm jack headphone output
1x Single-ended 3.5mm jack headphone output compatible with Mini Toslink
Supported sample ratesPCM up to 32bit 768kHz
DSD up to DSD1024
Supported Bluetooth codecsSBC, AAC, AptX, aptX HD
Bidirectional Bluetooth
Output power900mW @ 32 ohm
Operating systemAndroid 13
Battery7000mAh
ColorGray
Package1x Shanling M7T
InputWiFi
OutputJack 3.5mm
OutputBluetooth
OutputJack 4.4mm
OutputOptical Mini-Toslink
DAC / ADC ChipAK4498EX
Max sampling rate768kHz
Max sampling rateDSD1024
ColorGray
SHANLING M7T Digital Audio Player DAP Snapdragon 665 2x AK4498EX Bluetooth WiFi 32bit 768kHz DSD1024 Android Gray
The Shanling M7T digital audio player is based on audiophile components and an Android 13 operating system. It features two AKM AK4498EX DAC chips,...
