Audio Switch Board Jack 3.5mm 2 to 1
This switching module is equipped with two 3.5mm jack connectors at the input and a single 3.5mm jack at the output. Thus, it allows using an integrated button to select an active source among the two inputs to redirect it to the output. The module also has an XH2.54mm connector to add a second output connector.
Reference : 16672
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 02-07-2025.
Audio Switch Board
Jack 3.5mm 2 to 1
Module commutateur audio Jack 3.5mm 2 vers 1
Product typeAudio switch board
Inputs2x Jack 3.5mm
Outputs1x Jack 3.5mm
1x Analog output on XH2.54mm connector
PCB dimensions42 x 29.5mm
InputJack 3.5mm
OutputJack 3.5mm
OutputPCB Connector
This switching module is equipped with two 3.5mm jack connectors at the input and a single 3.5mm jack at the output. Thus, it allows using an...
