MEAN WELL LRS-350-5 Switch Power Supply 5V 60A 300W
This SMPS Mechan Well switching power supply delivering 5V 60A 300W is ideal for DIY projects.
Reference : 17202
39,90 €tax incl.
33,25 € tax excl.
Switching Power Supply Mean Well 5V 60A 300W
This SMPS Mechan Well switching power supply delivering 5V 60A 300W is ideal for DIY projects. Its compact form factor with its 3cm thick makes it easier to integrate. This power supply also incorporates interesting features, such as a selectable input voltage via a switch, short-circuit, overload, over boost and excessive temperature protection.
TECHNICAL CHARACTERISTICS
  • Output Voltage: 5V
  • Output Current: 60A
  • Max Output Power: 300W
  • Input voltage: 90 to 132 VAC, 180 to 264 VAC
  • Input frequency: 47 to 63 Hz
  • Max Input Current: 6.8A 115 VAC / 3.4A 230 VAC
  • Output connector type: Screw
  • Number of Outputs: 1
  • Yield: 83%
  • Min Temperature: -25 ° C
  • Max temperature: 70 °
  • Protections: short circuits, overloads, over-boosting and excessive temperatures
  • Dimensions: 21.59 x 11.43 x 3cm
  • Silver color
Schéma alimentation à découpage Mean Well LRS-350 48V 7.3A 350W
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output current (A)60
Input voltage (V)90.0
Input voltage (V)210.0
Input voltage (V)260.0
Input voltage (V)240.0
Input voltage (V)100.0
Input voltage (V)230.0
Input voltage (V)130.0
Input voltage (V)200.0
Input voltage (V)180.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)120.0
Input voltage (V)110.0
Input voltage (V)190.0
Power SupplySMPS
