By buying this product you get 25 loyalty points
Compact and easy to use, this power supply is ideal for integration into your high-power DIY projects for amplifiers in CLASS D from Sure Electronics (Sure AA-AB AB32274) by using two Mean Well MW SE-600 series power supplies, the module can be controlled SURE AA-AB32774 of 2x500w under 8 ohm
(Attention! Request a power input cable with a 3.5mm² cross-section)
PDF of the specifications available in the "Download" tab : Mean well serie 600.
The ventilation system of this power supply is permanently active to ensure proper cooling of its components.
Characteristics:
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 50.0 |
| Output voltage (V) | 43.0 |
| Output voltage (V) | 55.0 |
| Output voltage (V) | 56.0 |
| Output voltage (V) | 45.0 |
| Output current (A) | 20.8 |
| Input voltage (V) | 220.0 |
| Input voltage (V) | 250.0 |
| Input voltage (V) | 260.0 |
| Input voltage (V) | 190.0 |
| Input voltage (V) | 210.0 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 180.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 200.0 |
| Power Supply | SMPS |
