MEAN WELL NES-350-36 36 VDC 9.7A 350W Regulated Switching Power Supply
Reference : 10977
59,00 €tax incl.
49,17 € tax excl.
This high-quality 36 volt, 9.7 amp switching power supply is ideally suited for class D amplifiers.
It is specially recommended for Sure Electonics amplifiers compatible from 32V up to 40V for maximum powers of 350W.
Data sheet available in PDF in the tab to be downloaded.
Specifications:
  • Low noise switching power supply.
  • Input voltage from 90VAC to 132VAC and from 180VAC to 260VAC.
  • Output Voltage 32V to 40V DC by adjustable
  • Current Rating: 9.7A.
  • Efficiency: 87.5%.
  • Max output power 349W.
  • Frequency range from 47hz to 63Hz.
  • Leakage current max 240mV point to point.
  • Protection against overloading and temperature
Dimensions and weight:
  • 215 (L) x 115 (l) x 50 (H) mm.
  • Weight: 1.138Kg.
