Power On Softstart / Delay and Protection Board for Amplifier
This module allows to control the ignition of an amplifier. It has a standby, sotf-start, time delay and thermal protection function. It limits the current draw through the power supply capacitors and the transformer at start-up. It is connected directly to the 220V input. If no load is connected, you can find 220V at the output (capacitor in series).
Reference : 16065
30,90 €tax incl.
25,75 € tax excl.
Shipping date: 16-07-2025.
softstart Board
Module Softstart de Commande / Temporisation et Protection pour Amplificateur
When the soft-start is activated, the amplifier is powered through thermistors. After one second, the second relay switches on and connects the output directly to 220V.
Two mountable thermal sensors are also provided (with wiring) and trip at 75°C, allowing the power supply to be cut off instantly when this value is exceeded. A status LED is also provided, flashing when switched on and remaining lit when the module is in operation.
This module operates with a bistable switch. See accessories.
Module Softstart de Commande / Temporisation et Protection pour Amplificateur Module Softstart de Commande / Temporisation et Protection pour Amplificateur
This module does not eliminate ignition "bumps". A HP timer module can solve this problem.
It is possible that a residual voltage remains at the output in the OFF position. If this is the case, it is necessary to remove the capacitor between the two relays.
Product typeSoftstart board
Operating voltage220V
Power handling1500W
Relay current rating30A
Delay time~ 1s
Thermal protection trip (detectors to be mounted)75°C
Dimensions77.5 x 88mm
Mounting holes spacing69 x 79.5mm
Weight230g
Package1x Softstart board
2x Thermal sensors
4x Lugs
Screws and spacers
Wiring
3 reviews
Parfait...Le module fait son job.
This review has been posted for Power On Softstart / Delay and Protection Board for Amplifier
Parfait. Au TOP !!!
Parfait. Je ne regrette pas mon achat. Plus d'allumage "flashy" de mon Cayin à tubes. Je suis rassuré et très satisfait. Au TOP !!!
This module allows to control the ignition of an amplifier. It has a standby, sotf-start, time delay and thermal protection function. It limits the...
