LITTLE BEAR MC103-PRO Source Selector XLR
The Douk Audio MC103-Pro is a passive 3-way stereo source selector that supports three stereo XLR inputs and one stereo XLR output. It features a switch that allows you to easily switch between multiple audio sources and compare their performance.
Reference : 21598
59,91 €tax incl.
49,92 € tax excl.
Little Bear MC103-Pro Balanced Source Selector XLR 3 Inputs / 1 Output
The Douk Audio (Little Bear) MC103-Pro is a passive 3-way stereo source selector that supports three stereo XLR inputs and one stereo XLR output. It features a switch that allows you to easily switch between multiple audio sources and compare their performance.
With its aluminum housing and shielded channels, the MC103-Pro effectively minimizes interference, ensuring high-quality signal transmission. In addition, its XLR connectors are gold-plated to ensure reliable signal transmission.
The MC103-Pro's passive audio switch has no impact on sound quality, and its silver-plated contacts ensure excellent electrical conductivity. It features a simultaneous “Hot/Cold” switching mode as well as a common GND terminal.
The Little Bear MC103-Pro is compatible with most audio devices. However, if there is common-mode noise, please add an isolation module between the MC103-Pro and your device.
Product typeSource selector
Input3x balanced stereo XLR
Output1x balanced stereo XLR
Dimensions148 x 105 x 69mm
Net weight470g
MaterialAluminium
Package1x Little Bear MC103-Pro
InputXLR
LITTLE BEAR MC103-PRO Source Selector XLR 3 Inputs / 1 Output
The Douk Audio MC103-Pro is a passive 3-way stereo source selector that supports three stereo XLR inputs and one stereo XLR output. It features a...
