DAYTON AUDIO XO3W-700/5.6K 3-Way Speaker Crossover 700Hz - 5600Hz
This second order (12dB/octave) 3-way crossover filter has been designed with a 3 octave spacing between crossover points. Dayton Audio metallized polyester film capacitors and an 18AWG section coil are used on the midrange and treble channels. A 20AWG coil is used for bass. These coils keep DC resistance to a minimum.
Reference : 14644
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 06-05-2026.
Grantie 5 ans
Dayton Audio XO3W-700/5.6K
Dayton Audio XO3W-700/5.6K Filtre Crossover 3 Voies 700/5600Hz
The unique design of the low-pass section allows the use of woofers from 8Ω or 4Ω: ideal for setting up a multi-woofer system. The medium and high-pass sections are designed for a load of 8Ω. All components are glued or clamped to eliminate vibration and buzzing.
Product typeCrossover
Number of ways3
Power handling300W
Dimensions28.9 x 11.1 x 5.1cm
This second order (12dB/octave) 3-way crossover filter has been designed with a 3 octave spacing between crossover points. Dayton Audio metallized...
