ELIPSON PRESTIGE FACET 6B Bookshelf Speakers 2 Way 90dB 57Hz - 25kHz Black (Pair)
The Elipson Prestige Facet 6B is part of a complete range of high-fidelity loudspeakers, for which the French manufacturer unveils numerous technological innovations. The most obvious is the faceted crown, surrounding each speaker, and giving its name to the range: Facet. The whole series benefits from a rigorous design, with the aim of optimizing the acoustic performances, as well as a meticulous finish for an easy integration in all interiors.
By buying this product you get 32 loyalty points
Reference : 14814
325,00 €tax excl.
Including 0,04 € for green tax
Shipping from France
Billing in France
Technical support in France
If you buy this pair of speakers with a product from our categories DAC or Amplifier, take advantage of an exceptional discount directly in your basket!
Elipson Prestige Facet 6B Enceintes Bibliothèques 2 Voies 90dB 57Hz - 25kHz Noir (La paire)
The Elipson PF6B compact loudspeaker features a 14cm diameter mid-bass driver with a central ogive to limit turbulence, a cause of distortion. The tweeter is a 25mm diameter dome model. These transducers are made according to very demanding specifications. Exclusive to the Prestige Facet range, a custom-made synthetic rubber crown surrounds each driver to limit the baffle effect and diffraction. The response curve is thus less disturbed and more linear, for a soft and musical listening experience.
The cabinet of the speaker is not to be outdone, and also benefits from a very careful design. The front panel is made of two materials of different densities and thicknesses to eliminate internal vibrations and resonances as much as possible. The cabinet also incorporates numerous internal reinforcements. The steeply sloped filtering system uses audiophile components.
The facade is just as neat, lacquered and has high-quality vinyl cladding. At the rear, a high-end double terminal block allows bi-wiring or bi-amplification. The contacts of these terminal blocks are silver plated to maximize conductivity and thus promote signal transmission.
From a sound point of view, the Prestige Facet 6B are characterized by a great neutrality and accuracy. Devoid of any coloration, they deliver the audio message without adding or subtracting anything to the original recording, each piece being reproduced faithfully, masterfully and without aggressiveness. Conceived in an audiophile approach, these loudspeakers are designed to be associated with any high-fidelity amplifier with a power less than or equal to 70W per channel.
Product typeBookshelf speakers
Type2 way
LoadBass-reflex
Power handling70W RMS
DriversMedium-Bass : 140mm
Tweeter : 25mm
Frequency response57Hz - 25kHz (±3dB)
Sensitivity90dB/1W/1m
Impedance6Ω
ConnectorsBi-wiring or bi-amplification compatible screw terminals
Dimensions176 x 298 x 225mm
Weight5.6kg
FinishLacquered front, vinyl housing
Speaker Power (W RMS)70.0
ConfigurationBi-Wiring
ConfigurationMono-Wiring
ConfigurationBi-Amplification
Impedance (Ω)6
Loudspeaker diameter (mm)140.0
Efficiency / Sensitivity (dB)90.0
Lowest frequency (Hz)57
Highest frequency (Hz)25000
Power (W)70.0
Number of ways2
Number of loudspeakers2
Colissimo - TNT - SoColissimo
The Elipson Prestige Facet 6B is part of a complete range of high-fidelity loudspeakers, for which the French manufacturer unveils numerous...
