YB
Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay
The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device. Practical, it allows you to limit the cables running through your audio system, while giving you the possibility to control the playback remotely.
In this V3 version, the Up2Stream Mini is equipped with additional features and optimizations:
Very simple to set up, a mobile control application can be downloaded for free, to allow you to control the different Up2Stream receivers in your network in a multiroom integration.
The application is compatible with many streaming services, such as Spotify, Deezer, Tidal, Qobuz, Amazon Music, Pandora, Napster, iHeart Radio and web radios. It will also allow you to go to the files stored on your NAS. The Up2Stream Mini V3 can also be connected to a computer to function as a USB DAC.
Product type | WiFi / Bluetooth receiver |
Connectivity | WiFi IEEE802.11 b/g/n 2.4G Bluetooth 5.0 (SBC / AAC) |
Audio outputs | 1x Jack 3.5mm output / 1x Connector 4 pins 1x SPDIF 7 pins output (44.1kHz) |
Frequency response | 20Hz - 20kHz |
SNR | 100dB @ 0dBFS, 1kHz |
THD+N | 0.03% @ 0dBFS, 1kHz |
Supported formats | FLAC, MP3, AAC, AAC+, ALAC, APE, WAV |
Decoding | PCM up to 24bit 192kHz |
Supported streaming protocols | DLNA, UPnP, Spotify Connect, AirPlay, QPlay |
NAS Support | NAS avec support DLNA |
Power supply | 5VDC 1A on 2 pins connector 5VDC 1A via Micro USB |
Dimensions | 55 x 45 x 12mm |
Package | 1x Arylic Up2Stream Mini V3 1x PH2.0 4 pins cable 1x PH2.0 7 pins cable 1x 2 pins power cable 1x WiFi Antenna |
Input | Bluetooth |
Input | WiFi |
Output | PH 2.0mm |
Output | Jack 3.5mm |
Output | S/PDIF |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Yves B.
eric b.
Charles M.
