DAYTON AUDIO SPA100-D Class D Amplifier for Subwoofer 100W 20Hz-200Hz
The Dayton Audio SPA100-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in enclosures or cabinets that cannot accommodate a larger amplifier. The Class D architecture gives it a small size while offering high efficiency and low noise.
Reference : 16607
145,00 €tax incl.
120,83 € tax excl.
Shipping date: 01-07-2025.
Grantie 5 ans
Dayton Audio SPA100D Amplificateur Class D pour Subwoofer 100W 20Hz-200Hz
Connectivity
1. Power supply input : Power supply on IEC connector.
2. Low level input (left/right) : Accept line level signals from a preamplifier.
3. Output cables for subwoofer : Allows the amplifier module to be connected to the subwoofer.
4. Power supply/clipping LED : This LED indicator shows the current status of the amplifier.
5. Volume (Gain) : This button allows you to adapt the input sensitivity of the amplifier to the output of the preamplifier.
6. Frequency (low pass crossover) : This button sets the highest frequency reproduced by the subwoofer, over a range of 40-200Hz with a slope of 18dB/oct.
7. Phase : This switch allows to compensate the differences between the acoustic and electrical characteristics of the subwoofer and the main speakers.
8. Auto ON/OFF : This switch enables or disables the Auto ON/OFF function. When Auto is selected, the amplifier goes into standby mode and turns on automatically when a signal is detected.
9. Bass Boost : This function adds a 6dB boost to the response at 30Hz.
10. Power button : this switch is used to power up the amplifier.
Product typeSubwoofer amplifier
Amplification typeClass D
Output powerRMS : 100W
Max : 200W
Frequency response20Hz - 200Hz
Input sensitivity180mV
SNR (A-Weighted)90dB
THD< 1%
Dimensions204.8 x 179.4 x 54mm
Weight725g
OutputNC
Amplifier chipN/A
Power (W)100.0
3 reviews
Dayton Audio SPA 100 D
Ce petit ampli avec filtre actif convient très bien à l'usage auquel il est destiné. Il alimente chez moi un infraflex de 85 cm de diamètre coupé à 60-70 Hz la fonction bass boost m'est donc sans intérêt. ,A la place , j'aurais juste aimé une option de pente à 24 dB/oct mais la pente de 18 est correctement choisie . La classe D va très bien ici puisqu'on ne lui demande pas de médium. Bon achat.
This review has been posted for DAYTON AUDIO SPA100-D Class D Amplifier for Subwoofer 100W 20Hz-200Hz
Parfait et de bonne facture
Très bonne carte pour remplacer celle d'un Sub Klipsch avec un peu de découpe quand même (côtes légèrement différentes) et une plaque support en mdf, mais rien de bien difficile.
La qualité de fabrication est sans comparaison avec la Klipsch (je suis d'ailleurs très en colère contre ce constructeur pour cette partie ampli, qui à rendu l'âme 3 mois après la fin de la garantie). J’aurai du rester sur du Focal (comme toutes mes enceintes), au moins c'est français et il y a un support accessible. La carte Klipsch est "cheap", les composants recouverts d'une pâte blanche .. pour éviter de les changer ? Bref un scandale. Obsolescence programmée ? En tous cas, cela me faisait mal au cœur de changer tout le sub !
Celle-ci est de très bonne facture. Deux remarques: moins puissante (mais j'ai augmenté le signal sub de l'ampli) et câble secteur "UK" ..
Super ampli adapté sur mon ancien SUB ESPACE TRIANGLE 2 voies
Efficace, sans souffle, pas de bruit de coupure,
Je recommande ce produit.
The Dayton Audio SPA100-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it...
