DAYTON AUDIO SPA250 Subwoofer Amplifier Module 250W
The SPA250 is a flat subwoofer with a Class AB amplifier that offers the efficiency of a Class D amplifier thanks to a state-of-the-art design.
By buying this product you get 27 loyalty points
Reference : 10294
279,90 €tax incl.
233,25 € tax excl.
Grantie 5 ans
Attention: The product is delivered configured in 110V. If your electrical network provides a voltage of 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device before connecting it to the mains. An incorrect setting could damage your device.
Dayton Audio SPA250
Amplifier / Subwoofer module 250W
Dayton Audio SPA250 Module Amplificateur pour Subwoofer 250W
This amplifier uses a circuit that continuously monitors the input signal in order to modulate or regulate the voltage available at the output stage. Thus, only the necessary power is delivered.
Please note that this device needs a power cord to run. This item is not included.
Output power 8 Ohm156W
Output power 4 Ohm252W @ 0.1% THD
Inputsx1 RCA (LFE Mono)
Speaker terminal
Outputx1 RCA
Speaker terminal
Input impedance10.4 KOhm
Digital equalizerLow pass : 40Hz - 180Hz
Volume control-14.5dB / +dB
SNR90dB
THD0.92%
Active adjustable filter80Hz - 180Hz
Adjustable gainDe 0 à +10dB
Bass Boost Function+6dB à 35Hz
High pass filter12dB/oct
Phase adjustment0° (NOR) ou 180° (REV)
Frequency response30Hz - 200Hz
Efficicency66%
Damping factor114 - 100Hz
Dimensions250 x 250 x 13mm
InputSpeaker terminals
OutputSpeaker terminal
ClassClass A / AB
Amplifier chipN/A
Power (W)250.0
5 reviews
Rewarding purchase
I needed a new sub amplifier module since my previous one suddenly stopped working. After checking the options and the reviews on the internet I decided to take the Dayton SPA250. It arrived few days after placing the order and I am really satisfied of both the quality of the amp and the efficiency of Audiophonics staff. Right now I am running it in, but I can already appreciate its powerful and clean delivery.
This review has been posted for DAYTON AUDIO SPA250 Subwoofer Amplifier Module 250W
DAYTON AUDIO SPA250 Module Amplificateur Subwoofer 250W - Avis sur la commande
Bonjour, très satisfait sur le produit, le client et moi-même, sont ravis.
Très bon suivi sur la commande et la livraison, et également suivi téléphonique.
Très efficace au rendu du son et réglages.
Très bien emballé et conditionné.
A bientôt pour d'autres commandes.
Cdt.
Très bien !
Acheté pour alimenter un caisson de basse hifi DIY. Très bon produit, bonnes finitions et écoute très satisfaisante. Attention, l'amplificateur est réglé pour du 115v (ne pas oublié de switcher en 220) et le cordon d'alimentation fourni est une fiche anglaise!
installation module dayton audio SPA250
Installé en remplacement d'un ampli défectueux sur caisson de graves de marque Cabasse, j'ai été très agréablement surpris par le rendu de graves obtenu.
Excellent produit que je recommande.
Très bon produit
Correspond à la description
Je l'ai installé en nomade et non intégré dans le caisson
