Ampli mis en place dans mon caisson de basse fabriqué maison , fonctionne très bien.
Merci beaucoup livraison rapide .
By buying this product you get 23 loyalty points
Class D Amplifier for Subwoofer 300W 20Hz-200Hz
The Dayton Audio SPA300-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in enclosures or cabinets that cannot accommodate a larger amplifier. The Class D architecture gives it a small size while offering high efficiency and low noise.
Remember to check the power supply voltage selection switch before connecting the amplifier to the mains.
USB Power output : 5V 500mA via USB-A. This output provides power supply when the amplifier is switched on or in standby.
Low level input (left/right) : Accepts line level signals from a preamplifier.
Output cables for subwoofer : Connect the amplifier module to the subwoofer.
Power input : Power supply on IEC connector.
Power/clipping LED : This LED indicator shows the current status of the amplifier.
Volume (Gain) : This button allows you to adapt the input sensitivity of the amplifier to the output of the preamplifier
Frequency (low pass crossover) : This knob sets the highest frequency reproduced by the subwoofer, over a range of 40-200Hz with a slope of 18dB/oct.
Phase : This switch allows you to compensate for differences between the acoustic and electrical characteristics of the subwoofer and the main speakers.
Auto ON/OFF : This switch enables or disables the Auto ON/OFF function. When Auto is selected, the amplifier goes into standby mode and turns on automatically when a signal is detected.
Bass Boost : This function adds a 6dB boost to the 30Hz response.
Supply voltage selector : This switch allows you to select the power supply voltage of the amplifier, depending on the voltage delivered by your electrical network.
Product type | Subwoofer amplifier |
Amplification type | Class D |
Output power | RMS : 300W Max : 600W |
Frequency response | 20Hz - 200Hz |
Input sensitivity | 200mV |
SNR (A-Weighted) | 101dB |
THD | < 1.5% |
Dimensions | 204.8 x 179.4 x 54mm |
Weight | 997.9g |
Color | Black |
Power cable | Included |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Steve D.
gerard p.
