DAYTON AUDIO SPA500 Subwoofer Amplifier Module 500W
Lhe SPA500 is a flat subwoofer with a Class AB amplifier that offers the efficiency of a Class D amplifier through state-of-the-art design.
By buying this product you get 54 loyalty points
Reference : 8895
549,00 €tax incl.
457,50 € tax excl.
This product is temporarily unavailable.
Grantie 5 ans
Attention: The product is delivered configured in 110V. If your electrical network supplies a voltage of 220V (Europe), it is imperative to configure the device in 220V, as explained in the manual. An incorrect setting could damage your device.
Dayton Audio SPA500
Amplifier Subwoofer Module 500W
Dayton Audio SPA500 Module Amplificateur Subwoofer 500W
This amplifier uses a circuit that continuously monitors the input signal in order to modulate or regulate the voltage available at the output stage. Thus, only the necessary power is delivered.
Datasheet Dayton Audio SPA500
Output power 8 Ohm273W
Output power 4 Ohm540W
Inputsx2
Outputx1
Input impedance12 KOhm
Output connectorsSur fils
Input connectorsRCA
SNR98dB
THD0.92%
EqualizerFrequency : 18Hz - 80Hz
Bandwidth : 0.1 - 1 Q
Level : -14.5dB ++dB
Phase adjustment0° (NOR) or 180° (REV)
Frequency response30Hz - 200Hz
Efficiency75%
Dimensions250 x 250mm
InputSpeaker terminals
OutputNC
Impedance (Ω)NC
Loudspeaker diameter (mm)N/A
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
ClassClass A / AB
Amplifier chipN/A
Power (W)500.0
