JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.68µF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 10015
14,40 €tax incl.
12,00 € tax excl.
Shipping date: 01-10-2026.
Jantzen Audio Superior Z-Cap
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity0.68µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ16 x 43mm
Poids14g
Tolerance (%)2
Capacitor capacitance (µF)0.068
Rated voltage (V)800
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Tout simplement le meilleur rapport qualité-prix que je connaisse.
Le rendu à un petit quelque chose d'analogique...
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.68µF
My favorite
I tried several polyprop capacitors. This Jantzen line has a great value/price.
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
