OYAIDE INS-BS Brass Feet (Set x4)
These Oyaide INS-BS insulating feet are machined from brass, a material renowned for its mechanical rigidity and vibration dissipation properties. They are designed to limit unwanted resonance while maintaining the structural stability of the devices they support. A carbon composite (FRP) plate is integrated on one side to optimise vibration transmission and absorption, while protecting the contact surface.
Reference : 21071
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 12-05-2026.
Oyaide INS-BS Brass Feet Ø35x15mm (Set x4)
OYAIDE INS-BS : set of 4
Their four-sided tilted profile, obtained through precision CNC machining, facilitates positioning under equipment even in confined spaces. Their reversible design allows them to be used with either the carbon or brass side in contact, offering flexibility of integration according to requirements. A central bore is also provided for mounting with M4 screws when one wishes for direct mechanical coupling with the device chassis.
Product typeFeet
DimensionsØ35 x 15mm
MaterialsBrass
Carbon composite (FRP)
Cylinder boreØ5mm
Admissible load200kg/foot
ColorSilver
PackageSold by 4
Diameter (mm)35.0
MaterialCarbon
MaterialBrass
Height15.0
OYAIDE INS-BS Brass Feet Ø35x15mm (Set x4)
These Oyaide INS-BS insulating feet are machined from brass, a material renowned for its mechanical rigidity and vibration dissipation properties....
