Connector
Max cable diameter (mm)
Section (mm²)
0 mm - 6 mm
Contacts Material (Connector)
Contacts Plating (Connector)
Pavel V.
Good and tight plugs
Good and tight plugs, but despite my impression from the pictures, there is actually no grooving to put on a coloured rubber...
Pavel V.
Excellent amplifier with a power-on issue
Excellent amplifier. The only serious issue: it can frequently trip sensitive circuit breakers on start-up. The NC252MP...
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz)...
Terminals
Discover our range of cable lugs, in various sizes and formats, for the creation of your cables allowing fast and simple connections.
