RAMM AUDIO 30891GTC RCA Connectors (Set x4)
With the 30891GT_C, Ramm Audio offers high-quality RCA connectors with tellurium copper conductors, combining excellent rigidity with good conductivity. The contacts are gold-plated to provide unbeatable resistance to corrosion and oxidation. The connector body is made of demagnetised aluminium, minimising interference. Finally, the entire unit has undergone cryogenic treatment at -196°C to achieve optimal conductivity.
2.0 / 5
Reference : 20844
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 17-11-2026.
Ramm Audio 30891GT_C RCA Connectors Gold-plated Tellurium Copper Cryogenic Treatment Ø10mm (Set x4)
RAMM AUDIO 30891GT_C : Front view
With the 30891GT_C, Ramm Audio offers high-quality RCA connectors with tellurium copper contacts, combining excellent rigidity with good conductivity. The contacts are gold-plated to provide unbeatable resistance to corrosion and oxidation. The connector body is made of demagnetised aluminium, minimising interference. Finally, the entire unit has undergone cryogenic treatment at -196°C to achieve optimal conductivity.
Product typeRCA Connectors
Contacts materialTellurium copper
Contacts platingGold
Contacts treatmentCryogenic
Max. cable diameterØ10mm
Mounting typeTo screw
Maximum voltage/current250V / 6A
InsulationTeflon
Housing materialAluminum
Contact resistance0.02Ω
Dimensions13.6 x 52mm
ColorBlue
PackageSet of 4
Max cable diameter (mm)10.0
ConnecticMale
Contacts Material (Connector)Tellurium Copper
Connecteurs inutilisables
De très belle conception sur le papier, les connecteurs sont malheureusement inutilisables à cause de la vis M2 trop petite pour fixer l'extrémité d'un fil de câblage. Des que la vis est serrée à minima, le filetage cède et rend toute fixation impossible. Une vis M3 ou M3.5 pourrait peut-être résoudre ce problème chez RAMM. Quel dommage ! Merci tout de même à Audiophonics de proposer un choix de connecteurs de grande qualité.
This review has been posted for RAMM AUDIO 30891GTC RCA Connectors Gold Plated Tellurium Copper Cryogenic Treatment Ø10mm (Set x4)
With the 30891GT_C, Ramm Audio offers high-quality RCA connectors with tellurium copper conductors, combining excellent rigidity with good...
