The SCHUKO-01RC from Ramm Audio is a Schuko connector with a high-quality black nylon and polycarbonate body. Aesthetic and sturdy, this chassis is ideal for integrating sophisticated, high-end cables. Its proportions make it the perfect choice for cables and conductors with a large diameter.
This connector accepts cables with a diameter of up to Ø17mm. Thanks to a rubber cable clamp, your thick cables will be held securely in place. The pure copper contacts are cryogenically treated and plated with 3µ thick 24k gold for maximum conductivity and increased resistance to oxidation and corrosion.
Finally, it should also be noted that the internal connection terminals are equipped with large fixing screws and a particularly large contact surface. This means that no soldering is required to integrate your cable, and large-diameter conductors are held firmly in place.
| Specifications | |
| Product type | Male Schuko connector |
| Mounting type | To screw |
| Max cable diameter | Ø17mm |
| Max conductors section | 5.26mm² (10 AWG) |
| Contacts treatment | Cryogenic |
| Contacts plating | Gold 24k 3µ |
| Conductive material | Pure cooper |
| Current / Voltage | 16A / 250V |
| General | |
| Dimensions | 39.5 x 92.6mm |
| Weight | 82g |
| Color | Black |
| Package | Sold by unit |
| Max cable diameter (mm) | 17.0 |
| Connectic | Male |
| Connector | Schuko |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | 16.0 |
