Connector
Max cable diameter (mm)
Section (mm²)
0 mm - 6 mm
Contacts Material (Connector)
Contacts Plating (Connector)
Nicolas B.
Steve D.
Dayton spa300-D
Genalex
Terminals
Discover our range of cable lugs, in various sizes and formats, for the creation of your cables allowing fast and simple connections.
