PSVANE ACME 2A3 Triode Power Tubes (Matched Pair)
Psvane ACME 2A3 tubes are high-end triode power tubes offering exceptional audio performance with a typically analogue sound. This version of the 2A3 tubes features gold plating on the control grid for maximum dissipation and undergoes meticulous burn-in by Psvane.
By buying this product you get 64 loyalty points
Reference : 21210
649,00 €tax incl.
540,83 € tax excl.
Shipping date: 13-05-2026.
3 >Month warranty
Psvane ACME 2A3 Triode Power Tubes (Matched Pair)
Psvane ACME 2A3 : Front view
Psvane
 ACME 2A3 tubes
Psvane ACME 2A3: 24-hour burn-in period
To ensure stable voltage and temperature, Psvane ACME 2A3 tubes undergo rigorous quality control and are run in for at least 24 hours before leaving the factory.
Psvane ACME 2A3 breaking in
Psvane ACME 2A3 in use
Psvane ACME 2A3: Analogue sound
The Psvane ACME 2A3s deliver a typically analogue sound, with a warm, rounded tone that gives prominence to the bass and mid-range frequencies. They also ensure smooth reproduction of the high frequencies, avoiding any harshness that could tire the ear during long listening sessions.
Product typePower tubes
Tube typeTriode
Maximum ratings
Anode operating voltages (Ua)5V
Anode power dissipation (Pa)15W
External resistance control grid (RG)With cathode bias : 0.5MΩ
With fixed bias : 0.05Ω
Electrical parameter
Anode operating voltages (Ua)300V
Grid control voltage (-Ug)45V
Anode current (Ia)60mA
Mutual conductance (Gm)5.25mA/V
Control grid impedance (ri)0.8KΩ
Amplification factor (μ)4.2
Output power (Pout)3.5W
Inter-electrode capacitancesInput : 7.5PF
Output : 16.5PF
Grid to plate : 5.5PF
Recommended operating conditions Class A, single tube
Anode operating voltages (Ua)250V
Recommended load impedance (RL)2.5kΩ
Control grid impedance (ri)0.8 KΩ
Recommended operating conditions Class AB, push-pull
Grid control voltage (-Ug)62V
Cathode resistance (Rk)780Ω
Recommended load impedance (RL)5kΩ
Anode current (Ia)80mA
Output power (Pout)10W
PackageMatched Pair
Contacts number4
Tube typeTriode
Excellent tube
ce tube 2A3 apporte une transparence étonnante, beaucoup de dynamique, de détails et de naturel. Tout est très juste. Les transitoires d'attaque de notes sont très rapides, mais sans dureté.Tout cela donne un réalisme rare à la musique, si le reste du système le permet. Un régal!
j'avais déjà des PSVANE TII et des W275 Replica. Les ACME viennent couronner le tout.
This review has been posted for PSVANE ACME 2A3 Triode Power Tubes (Matched Pair)
Psvane ACME 2A3 tubes are high-end triode power tubes offering exceptional audio performance with a typically analogue sound. This version of the...
