Premium twin triode tube
The TAD 7025 HIGHGRADE is a double triode tube designed for the most demanding amplifier stages. It offers a smooth and clear reproduction with deep bass. It can be used especially on a first gain stage in high-end designs. This model can also replace the ECC83, E83CC, 12AX7, 12AX7A, 12AX7M, 12AX7WA/WB/WC/LPS/EH, 5751 or 7025 tubes.
Product type | Tube |
Tube type | Twin triode |
Number of pins | 9 |
Dimensions | Ø22.5 x 56.6mm |
Weight | 13g |
Electrical parameters | ||
Parameter | Serie | Parallel |
Heater voltage (AC or DC) | 12.6V ±1V | 6.3V ±0.5V |
Heater current | 0.15A | 0.3A |
Cathode to heater potential | 150V | |
Direct interelectrode capacitances | Grid to plate : 1.5pF Grid to cathode : 1.7pF Grid to heater : 0.2pF Plate to cathode : 0.3pF |
Max values | |
DC plate votlage | 330V |
Positive DC grid voltage | 0V |
Negative DC grid votlage | -55V |
Plate dissipation | 1.2W |
Bulb temperature at the hottest point | 160°C |
Cathode current | 8mA |
