MOGAMI 2524 Asymmetrical modulation cable 0.56mm² Ø6mm
The MOGAMI 2524 interconnect cable is an unbalanced interconnect cable with OFC copper conductor and shielding. It is specially designed to transmit signals from instruments such as guitars, thanks to a layer of conductive PVC placed under the shielding.
4.4 / 5
Reference : 7416
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 19-05-2026.
MAGAMI 2524
MOGAMI 2524
Features:
Download the documentation in PDF: right here
Configuration
ConductorDetails50 / 0.12A
Size (mm²) 0.565mm² (# 20AWG)
InsulationOv.Dia (mm)2.7Ø (0.106 ")
MaterialPE
colorClear
Sub-ShieldOv.Dia (mm)3.3Ø (0.130 ")
MaterialConductive PVC (Carbon PVC)
colorBlack
Hand-ShieldServed-ShieldApprox. 55 / 0.18A
JacketOv.Dia (mm)
MaterialPVC
colorBlack
Roll Sizes100m (328Ft) / 200m (656Ft)
Weight per 100m (328Ft) roll5.1kg
Electrical & Mechanical characteristics:
DC Resistance at 20 ° CInner Conductor0.033Ω / m (0.010Ω / Ft)
Shield Conductor0.014Ω / m (0.0043Ω / Ft)
Capacitance at 1kHz, 20 ° C 130pF / m (39.7pF / Ft)
Inductance0.2μH / m (0.061μH / Ft)
Electrostatic Noize *0.15mV Max.
Electromagnetic Noise At 10kHz *0.07mV Max.
microphonics *0.3mV Max
Insulation Resistance100000 MΩ × m Min. at DC 500V, 20 ° C
Flex Life15,000cyles
Tensile Strength (26 ° C, 65% RH) 578 N
EmigrationNon-emigrant to ABS resin
Applicable Temperature-20 ° C~ + 60 ° C (-4 ° F. + 140 ° F)
Diameter (mm)6.0
Length (m)Sold by length
Number of conductors1
Insulation materialOther
ShieldingYes
Section (mm²)0.56
Ground / ShieldingYes
10 reviews
Audiophonics Transaction parfaite.
Bonjour, j'ai commandé ce câble pour liaison Guitare vers Ampli.
Demande technique avant vente , réponse reçue dans la journée
le service est très réactif et surtout de bon conseil.
Commande reçue très rapidement en point relais, le tout à un tarif très doux.
Merci à l'équipe Audiophonics,
This review has been posted for MOGAMI 2524 Asymmetrical modulation cable 0.56mm² Ø6mm
Mon ami
Câble qui se travaille très bien et qu'il est bien construit avec de bons matériaux . Je trouve qu'il est équilibré niveau tonalité associé à des jacks Neutrik N2X pour le branchement guitare . Pour les soudures le site Neutrik fournit schéma et indications , c'est parfait avec en plus la rapidité d'expédition et de livraison . Merci 1001 X .
MOGAMI W2524
Est parfait pour cable secteur. La qualité est au rdv!
La qualité Mogami tout simplement....
Utilisé pour réaliser un câble instrument avec deux jack Neutrik et ainsi remplacer mon câble MonsterCable. Et bien c’est le jour et la nuit, un son plus chaleureux et je redécouvre ma Les Paul avec mon tout lampe Marshall...
Prêt à relier tous les maillons
La gaine extérieure est résistante et souple à la fois. Le point chaud de 0.56mm² est protégé par 2 gaines. J'ai donc confectionné un câble jumelé à l'aide de ruban adhésif auquel j'ai raccordé des fiches RCA Elecaudio TE RC90S. (la soudure se fait aisément).
Je l'ai raccordé entre mon lecteur DVD et l'amplificateur, en lieu et place d'un câble de 0,20mm². Certes le diamètre plus élevé augmente la capacitance, mais sur les 45cm du cordon c'est insignifiant, d'autant plus que l'effet capacitif n'influe que sur des fréquences au delà de 20khz. Résultat, même si l'appréciation a toujours un coté subjectif , au delà du son qui était déjà très beau, j'ai la nette impression d'avoir fait un gain au niveau de l'énergie restituée. je vais de ce fait remplacer le câblage
des autres maillons de la chaîne.
The MOGAMI 2524 interconnect cable is an unbalanced interconnect cable with OFC copper conductor and shielding. It is specially designed to...
